DisplayPort Dual Mode in Fury?
1,959 (0.26/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
i started to read the fury x manual and am not sure if am reading this correctly but the fury x manual says this
When connecting displays to a DisplayPort connection, the type of adapter and display that you use may determine the number of displays that can be used with your graphics card.
• An active adapter allows a non-DisplayPort display to be connected a DisplayPort connection using DisplayPort signals.
• A passive adapter also allows a non-DisplayPort display to be connected to a DisplayPort connection but using non-DisplayPort signals.
• Transmission of audio and video information between variants of the same connection type (for example, Mini DisplayPort to standard DisplayPort and vice versa) are considered to be native, active connections.
More information on the number and type of displays that can be supported by your graphics card is provided in the following sections.
The way am reading this is that the DP ports can output non-DP signals?.
If so that means it support DisplayPort Dual Mode
http://www.displayport.org/pr/vesa-...solution-interoperability-with-hdmi-displays/
another possibility is thunderbolt but i dont think its that
Passive and active adapters have been around for ages. Long story short: if you want to use Eyeinfinity you need active adapters.
The Fiji cards all support up to six displays.
2 on DP1 using MST
2 on DP2 using MST
2 on DP3 using MST (includes HDMI next to it)
