specks
- Feb 27, 2011
- 440 (0.08/day)
System Name | Spreadsheet powerhouse |
Processor | Two P4s glued together |
Motherboard | Asus P5KPL-AM EPU |
Cooling | CoolerMaster Hyper TX3 |
Memory | 2gb (2x1gb) Kingston Value Ram DDR2 800mhz |
Video Card(s) | Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7 |
Storage | 500GB Western Digital Caviar Blue |
Display(s) | Philips 191EL 18.5" |
Case | Thermaltake V4 Black Edition |
Audio Device(s) | Onboard |
Power Supply | Thermaltake TR2 600W |
Software | WinXp |
Im planning on transferring the innards of my system to a vacant space below my computer desk. Basically, it will be like a box. The motherboard will be laying horizontally on the desk with standoffs. The PSU will also be in the "box"which will also be sitting on standoffs to let the air flow underneath it. The front and side panels will be made out of plywood. The rear will also be made out of plywood but with a gap for the cables. On both sides there will be two 120mm fans, all intake. The top will be glass/plexiglass/acrylic. I've made the diagrams but I have a few headaches. Help me on this please(in the least expensive way). I already have some bolts, nuts, screws, some tools and plywood lying around.
These are the things i need some ppl to help me with:
1. A DIY Drive bay for Two 3.5" HDD and One 5.25" DVD-ROM. If possible, I want to make it out of wood, make it screwless but secure. The bay will be sitting on a piece of plywood which will be screwed to the desk.
2. How does the Power and Restart buttons work? I plan to make a mini panel with these buttons.
