Do you use Blend or Small FFT/CPU test in prime95/orthos?
Studabaker
1,116 (0.19/day)
Somewhere in the underground
System Name Built Entirely With Parts From CompUSA
Processor E7400 2.8 @ 3.6 [9.0*400/1.31v]
Motherboard Gigabyte EP45-UD3R
Cooling Masscool 8WA741
Memory 2x1GB Corsair XMS2 800 4-4-4-12
Video Card(s) BFG 9800GTX+OC; GTS250 BIOS
Storage 2x WD 250GB AAKS in RAID0!
Display(s) 19" I-Inc LCD @ 1440x900
Case Ultra X-Blaster Clear Side
Audio Device(s) Audigy with X-Fi drivers; Logitech X-540s
Power Supply Corsair TX750
Software Vista 32-Bit
I've always just used the Blend testing and never realized how much hotter the Small FFT test makes the chip, and that's with overclocking experience since back with the Celeron 366. I wanna what people's results are like when running the Small FFTs/CPU stress testing.
in orthos I use small fft, as blend I have read incorperated the HDDs somehow and could make it crash.
I use prime95, OCCT, and Orthos for just CPU... Memtest 86+ on CD to check ram.
OCCT has a couple options for just your CPU thats what I use for my stability tests.
yes OCCT 3.0 IMHO is way better for testing stability these days. Multiple testing methods, includes a GPU test, and has nice charts to verify voltage stability while the test was run.
Yes, I have also been using OCCT. I think it generates more heat than even Orthos on Small FFTs. I'm roasting my system as it is, so I'll wait til I get a better cooler. 3.8GHz simply isn't gonna happen with stock cooling, it's hitting 75C and rising. Back to 3.67.
I use both Prime95 SmallFTT(4-8hours) and Blend(8-10hours).
