Does Spread Spectrum has some other Name?
FireFox
The Power Of Intel
7,507 (1.83/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi there.
I want to disable the spread spectrum feature but i don't find it in my bios, and as the title says does it has some other name?
Thanks.
Is there Smart Clock?
Not Smart Clock found:banghead::banghead:
Are you experiencing issues where you need to disable the feature? Or is it habit from overclocking? I rarely disable such features anymore, OC-ing or not. Also is this for the system in your System Specs?
Let's say habit from overclocking, and yes it's for the System in my Specs.
K, that's a start for sure. I assumed that you were referring to your system, but it always pays to verify. :)
What about the first question I asked in my last post?... Are you experiencing issues where you need to disable the feature?
Sorry for not replying to that, not issues at all it's just me disabling all features that I don't need or are useless.
Honestly, I wouldn't bother with it. I believe Spread Spectrum's point is to reduce EMI, so it has a use even if its limited in various situations and executions. If you're not experiencing issues and can't find the setting, I see no point in getting too caught up in it. Especially if you're stable on your current OC. If it were causing a jitter or instability issue, or a shadow of a doubt, then I'd say let's find a way to disable for sure.
:toast:
The setting for Spread Spectrum appears to be under Frequency/Voltage Control menu.
Code:
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 200 )
MCH Strap ( 1600 )
CPU Uncore Frequency (Mhz) ( 4000 )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
