Does using Bluetooth Adapter on m50x affect quality? Is quality 100% same as wired?
Status
Not open for further replies.
477 (0.13/day)
System Name Rtxoned
Processor Intel i5 8600k
Motherboard Msi Z370 Sli Plus
Cooling Cooler Master Ml240r
Memory Corsair vengeance 8x2 DDR4 2400mhx
Video Card(s) Zotac Rtx 2080 Amp
Storage 250gb SSD, 500Gb SATA, 250Gb SATA
Display(s) Alienware 25” 240hz
Case Nzxt H700i
Power Supply Thermaltake toughpower 1000w 80+ Gold
Mouse Logitech 403
Keyboard Hyperx alloy fps mechanical keyboard Cherymx Blue
hi bros,
Im thinking to buy this for m50x.(will also use 2.5mm jack converter too)
http://s.aliexpress.com/mu2U7Fru
All know that its really high quality headphone, thats why people buy it, but does using that bluetooth adpater make audio quality changed?
Will the quality be same as wired?
Change of 1% of quality will make that gadget worthless.
Whats your opinion.
actually wired and wireless are the same, the difference just the media where it transfered, wired using copper wire or like that and wireless using wave
as long as you have no intervention
sometimes the judge is your ear and your taste
So is it fine should i order it?
No it's not the same. But close. Also BT has a slight lag in case you're thinking about using for video
RF and BT both have advantages and disadvantage. But wired has none. Except that you can't walk to far
whats your headset?
Audio Technica M50x
I can live with that latency but cant compromise quality. I request you guys please help me with this question because i dont want to waste money, can anyone explain clearly that is there any difference of sound quality in Bluetooth audio adapter and wired?
Sound is to subjective. BT quality is pretty good. Better than RF but not quite the same as wired. BT is digital so technically as long as it has a signal it sould be close. It's the power I'm not sure about so you lose some bass.
Definitely not the same unless you're running some mid-high end stuff afaik. Cheap BT will not be the same at all.
With BT the audio signal gets resampled so it can be sent at a lower bitrate through compression. It will sound worse , how much depends.
If thats true, then i think i should keep listening wired, i should stop thinking about that device. Thanks everyone, helped lot, thanks for saving money.
Status
