DOOM3 Error!!
Racing393
1 (0.00/day)
Hi
Sorry to post this long fault but after installing the latest softmod display drivers, I can no longer play Doom3 because of the error pasted below! I tried to put card in forced 16bit mode but still nothing. The game was working on official ATI drivers bit not the softmod versions. I have no issues with any other game.
Thanks in hopeful advance :confused: :confused: :confused: :confused:
DOOM 1.0.1282 win-x86 Sep 16 2004 16:45:51
2165 MHz AMD CPU with MMX & 3DNow! & SSE
512 MB System Memory
doom using MMX & SSE for SIMD processing
enabled Flush-To-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game00.pk4 with checksum 0x7dafc4d4
Loaded pk4 C:\Program Files\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Program Files\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Program Files\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Program Files\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Program Files\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Program Files\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak005.pk4 (63 files)
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5151 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
X..GL_EXT_texture_lod not found
X..GL_1.4_texture_lod_bias not found
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
