Dual channel memory causing excessive bsod, but single ram is running fine
debojitk
21 (0.00/day)
I have 2 2gb kingston installed in dual channel mode in a msi p45 neo board.
Those were not bought as pair but were running fine for past 3 years.
Recently I installed Win 7 and few days after that installation it started giving random blue dump.
earlier i had 8600 gt board with a standard power supply.
Yesterday I upgraded the board to zotac gtx 560, and the psu to corsair GS500.
Still it was giving bule dump, and even after a fresh installation the blue dump did not stop.
Then I ran P95 stress testing with ram testing, and found the workers stopped, and soon the system resulted in blue dump.
The bsods are some time MEMORY_MANAGEMENT, some times PAGE_FAULT_IN_NON_PAGED_AREA.
Then I removed one ram stick and tested both stick in standalone mode, and in standalone mode both are running fine without any error.With single ram the windows experience index is 5.5, where as in dual channel mode it is 7.1.
How should I test the rams and find out the original criminal, i mean the ram or the mobo.
Please help.
Thanks in advance.
ram kingston ddr2 800 mhz.
CaptainFailcon
194 (0.04/day)
sounds like the memory controller in the cpu is unstable try upping the CPU-NB voltage to about 1.25-1.3
if that fails to help I would suspect that the cpu is starting to degrade
debojitk
21 (0.00/day)
should i suspect the cpu or the mobo/ram
Thanks for your reply.
My CPU is C2Q 8200 and it is just 3 yrs old.
The hack you suggested I will apply today evening and see if it works.
I just wanted to know that increasing cpu nb voltage is safe or not.
Should I try changing the mobo slots.
CaptainFailcon
194 (0.04/day)
errhmm I assumed it was amd because you failed to fill in you'r system specs disregard what I said
I would reseat the cpu first > pull the cooler off > remove the cpu from the socket and reinstall it and use fresh thermal paste
LGV
260 (0.05/day)
System Name outdated
Processor AM2 6400+ X2 black @stock
Motherboard MSI K9N SLI @ HOT (very, 65+)
Cooling air
Memory 4x2GB OCZ @stock
Video Card(s) 260 gtx
Storage Hitachi 650 / ssd corsair force 3//120
Display(s) 26''
Case Cooler Master Centurion
Audio Device(s) Asus Xonar DX2/ Z5500 X2 :)
Power Supply Mushkin 1000W
Software Win7/64
Try other rams or/and your ram in other pc.
Maybe you can get RMA for thet CPU if under 3 years old.
For stable PC, please buy better PSU-s in the future.
LGV
260 (0.05/day)
Cooling air
Display(s) 26''
Software Win7/64
WHAT ?
what in the fuck are you babbling about
Im sorry if I make your head banged to the wall.
I try to narrow down the problem, find the problem what actually causing it.
Now the babbling part: Increase the volt-s may help in the short , but may just kill the falling part in hes PC + if he could find the part whats broken, may he is in the timeframe to RMA.
In short: increase the volt should hes LAST result, not first.
Best regards
debojitk
21 (0.00/day)
i am really confused why u guys are suspecting my cpu.
Thanks to u guys for replies.
But i am really confused why u guys are suspecting my cpu.
With single ram it is running rock solid stable.
Update: I have tested both rams individually in every slots, and both performed flawless.
Whenever I put two sticks together in dual/non-dual channel mode, P95 is failing like anything, and it happens when I choose the torture test for ram testing (3rd option in P95 torture test).
When I test CPU for maximum heat (In place FFT), it runs flawless.
I did that, I mean I tried increasing MCH voltage, but just wanted to know that NB voltage is the MCH voltage or the ICH voltage. Because my mobo is MSI P45 neo, and it does not have anything like NB voltage in its CELL Menu.
My ram timing is 6-6-6-18, and the Command rate (1T/2T) is kept auto.
Is there any scope to alter those settings.
If in any case the 2 ram stick scenario does not work with my current setting, Can I get a 4gb DDR2 1066 Mhz for my Mobo instead of 800 Mhz, beacuse I think the memory speed is becoming the bottleneck between my newly installed gtx 560 card, and the quad core cpu.
Note:
Win 7 system rating:
CPU: 7.1
Graphics: 7.6
ram:5.5 (single stick), 7.1 (double stick)
disk:5.8
Please suggest.
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Yes, MCH is NB voltage. On a core2quad, the mem controller is in the NB on the motherboard, not the cpu. You can go as high as 1.4v on the MCH, and you may need to bump up ram volts just a touch, but that's only if needed. Make sure to set for 2T command rate to eliminate any variables. You may need to bump up cpu volts a bit too, but only if the above didn't help.
debojitk
21 (0.00/day)
sorry for late reply
Hey guys,
I could not apply the changes you suggested because my new zotac gtx 560 is working no more. It is showing some garbled character on screen during booting just after POST, and when its time to load the desktop it is resulting in blue dumps with pink dots every where in the screen. Uninstalling/reinstalling driver could not solve the problem.
Should I consider that it is gone?
Please reply.
CaptainFailcon
194 (0.04/day)
Hey guys,
Please reply.
sounds pretty well dead to me next time buy EVGA/XFX
debojitk
21 (0.00/day)
u r right
my old evga 8800gt is working flawless from last 4.5 yrs w/o any problem.
I bought zotac because it was a bit cheap @$200, and evga gtx 560 was not available at retail shop, and i don't know how in future it is going to perform
CaptainFailcon
194 (0.04/day)
I won't ever buy zotac/power color
completely made in china with typical china "quality" you are lucky it didn't explode or suddenly fall into a sink hole
Paddan1000
1 (0.00/day)
I've seen this memory problem several times, where one or two stick works fine but two or three makes the computer unstable. The broken stick works fine on its own since the strain put on the memory bus is lower with only one stick, but with more RAM installed the workload increases and the faulty stick can't handle it.
The only way of diagnosing the faulty memory stick is to get an extra stick and test the two original ones against it, one at a time. Then you can discard the one that still gives errors.
As for the graphics card, test it in another computer and see if the problem persists. It might be possible that the problem is due to something simple, like overheating from a fan clogged up with dust or that the extra 6-pin power cable came off.
debojitk
21 (0.00/day)
@CaptainFialcon
I just bought the card a week back, and it is dead within a week. So at this point i can't shell out more money to get another card.
Can u give me solution to this problem. I mean any customization on the card like custom cooling etc.
debojitk
21 (0.00/day)
Hi Paddan,
u r right, i think i found the faulty ram stick and i m going to test with another stick.
can u tell me kingston lifetime warranty is really life time or less than that. i think i lost the cash memo of the ram stick
95Viper
Super Moderator
13,304 (2.20/day)
Kingston Limited Warranty Statement
Product Lifetime Warranty:
The following Kingston products are covered by this warranty for the life of the product:
Memory modules including ValueRAM®, HyperX®, Retail Memory and Kingston system-specific memory; Flash memory cards (e.g., Secure Digital, Secure Digital HC and XC, CompactFlash, MultiMediaCard, SmartMedia) and Flash adapters.
Read the section that pertains to your country or region, here> Warranty Claim Procedures and Requirements
EDIT:
P45 Neo
Supports four unbuffered DIMM of 1.8 Volt DDR2 667/800/1066* (OC) DRAM, 16GB Max.
Also, if, you know how to flash the bios and wish to take the risk... you may want to update to the latest; as, some bios updates had memory compatibility fixes.
Chances are the ram is good, if you run Memtest on the individual sticks and they pass.
I believe you have other things, possibly, going on. I am curious as to why the video card died so suddenly.
debojitk
21 (0.00/day)
@95 viper, how do you think of the above. I mean single stick mode working fine, but when double stick come it becomes unstable.
What else could be the problem, i mean do u want to infer any relationship with the video card dying incident with this ram issue.
But the thing is probably i have found a ram stick as guilty; in single stick mode the system is resulting in bsods when i ran p95 in ram testing torture mode.
Aonther thing - can i rely on memtest result for memory testing, because i tested the both rams even in dual channel mode with windows default memory diagnostic (MdSched.exe) in dos mode, and it did not find any error.
Now with the non-faulty ram and the old card system is again stable.
Please help me in identifying the actual root cause of all the issues.
Note: I have recently installed corsair gs 500 psu in my system.
Could you please suggest any other diagnostics
Thanks in advance.
Edit: When the card died the system was running with one ram and was stable with no frequent bsods
4,815 (0.74/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
In response to the original subject of the post, I think the memory controller on the motherboard is had it.
I had something similar happen with my old Core 2 rig although the chipset was a 680i.
The machine could run fine in single channel but would either black screen, come up with AMD VPU recover, bluescreen or reset all together.
CaptainFailcon
194 (0.04/day)
possible but not likey that almost never happens
4,815 (0.74/day)
Wangas, New Zealand
More of a chance than a degrading memory controller on a 775skt CPU.
Either way, the ram can be crossed out, and the I believe the CPU.
4,815 (0.74/day)
Wangas, New Zealand
its more likely that the gpu in the process of dieing was causing the error as well
Yet the OP states the bsods were occurring before the new GPU was installed.
95Viper
Super Moderator
13,304 (2.20/day)
Valid points.
I am leaning the way Widjaja is.
It could, also, be the NB, and/or the memory, needs a bump in voltage due to age and/or the motherboards memory controller is going.
Or, it could, even, be you may just need to set your voltages and memory timings manually.
What are the model numbers and timings on the two sticks?
What settings (voltages, timings, etc.) is the motherboard is using?
Run CPUz and/or HWInfo; take some screen shots of the voltages/timings and post them.
And, for grins and giggles; post a screen shot of your temps at idle and load, you can use Real Temp.
Also, run a good full scan on the Hard drive/s.
Look in your device manager and see if there are any problems.
Have you tried resetting the bios... like, removing the CMOS battery, moving the clear cmos dip jumper, or any other method. If not, try clearing the BIOS(CMOS).
If you still suspect a bad or dying stick of ram, then borrow/buy some, and test it.
If that seems to be it, RMA the ram.
It would be really nice to see some screen shots and hard numbers on the parts/settings, though, as most of this is guessing.
debojitk
21 (0.00/day)
Thanks Viper for your elaborate reply.
I did not get much time at home because of office work load.
I will post those screen shots asap.
The ram timing i remember is 6-6-6-18. Though i will verify and post the snaps
Thanks
