dvi to scart setup not working!
regan1985
1,449 (0.21/day)
Coventry UNI England
Processor yorkfield core 2 quad Q8200 3.2ghz 1.26v
Motherboard asus p5Q SE
Cooling akasa ak965
Memory Kingston 1066 2x2gb 1104mhz 2.2v
Video Card(s) SAPPHIRE HD 2600 XT DDR3 857/1078
Storage 2X Samsung spinpoint 500GB 7200 4x 1tb samsung eco 5400
Display(s) 2xSamsung P2270 22" Widescreen
Case NZXT Hush Quiet Case in Black
Power Supply OCZ StealthXStream 500w Silent Power Supply
Software windows 7 64
i have a problem,i purchased a vga to scart lead and then used my vga to dvi apator on it and found found out it was a vga female so i also puchased a male dvi to make vga adaptor, i pluged it all in and enabled it and i only seem to be getting a black screen with some lines i have no idea why?
What kind of vga> scart adapter did you buy?
It might have a maximum resolution, ie try lowering your resolution. Also, the fact that the scart to vga cable is using a female connector makes me wonder if it isn't meant to convert the other way around, ie scart signal on a monitor instead of PC signal on a TV.
i didnt read that bit, ive just wasted £10 ,not sure where else i can get one that does the job im looking for
i assume you want to use tv out of your card and feed it into scart plug of your tv.
the tv out cables from the card should be able to get you the video output into a yellow cinch plug. there are adapters like:
or the same with some cables which you can use.
yellow = video signal
red and white = audio signal left and right, grab those from the line out of your sound card with a 3.5 mm to dual cinch cable
