dx79si help
krondo
5 (0.00/day)
So I just built my second PC and am running into a problem
The system right now is setup like this dx79si 2gb skill z series ripjaw 2133 and pny 4gb 680 gtx no HDD yet just trying to boot to bios but I am getting no video signal what could be the problem here?
& the power supply is? what about the cpu?
looking at the bios updates right now, they sure have a ton of fixes, maybe you just need to update it
Sorry it is an i7 3820 and atx ultra x3 1000 watt with x4 cables
Hi
*Power down the sytem
1 Remove vga card and ram
2 Unplug 24pin & *8pin [*if required by mobo] Power from Motherboard & Clear CMOS
3 Install minimal hardware: PSU; CPU & Heatsink; one stick of RAM and vga card [*boot to bios; If NO]
4 Use Spare compatible RAM and or borrow from a friend if possible [*boot to bios; If NO]
5 Use Spare vga card and or borrow from a friend if possible [*boot to bios; If NO]
Reseat CPU *do not over tighten heatsink [check for bent pins and or other damage] and repeat process 1 through to 5
[*boot to bios; If NO] check with another monitor and vga; HDMI, DVI and or other cables
*Double check all PSU cables are secure [fans not spinning on mobo; no sign of life * check with another PSU] make sure your PSU is registered within the thirty day limit; incase it fails or develops a fault
Assemble system out side of case place mobo on anti static bag and box lid [to ensure the hardware is not shorting out]
Note: If able to see bios on screen; go here to update motherboard bios, once updated try with the original hardware config in the opening post
nb: try not to double post, use edit button if you need to add more information, thanks
Edit: attach system speaker so beep codes can be heard for mem and vga *if mobo gives errors
atb
Law-II
