ECS motherboard Bios flash
Darren
1,936 (0.26/day)
System Name Cheap yet powerful gaming and entertainment rig!
Processor AMD Athlon 3800+ X2 Windsor, 1 MB L2 Cache (512k L2 Per Core), 65W Energy efficient, 2GHz @ 2.78 Ghz
Motherboard Asrock ALiveNF7G-HD720p Rev v5.0
Cooling Freezer 64, 2x120mm, 1x92mm
Memory 8 GB DDRII PC6400 @ 929 MHz OCZ (2GBx4) timing: 5-5-5-5-16-2T
Video Card(s) XFX ATI4830
Storage Seagate 320 GB SATA (16 MB Cache)
Display(s) 19' HannsG (1440x900 @ 75hz)
Case Coolermaster Elite 330 Black Case
Audio Device(s) Auzentech X-Meridian, Pioneer VSX-516 Receiver 7.1 with DD/DD EX/Prologic II/DTS/DTS-ES//DTS: Neo
Power Supply Cool Master eXtreme Power 460W PSU
Software Vista Ultimate X64 Corporate Edition
Out of curiousity, Is it possible to flash an ECS NForce 3-A mothorbard's bios with another Nforce 3 bios of another manufacturer?
If the other board is nearly the same, various onboard things might fail though. They flashed a PC-DL with a Iwill.. something800 BIOS and it booted, though the irq tables and such were totally messed up, many things didnt work. It did add nocona support, which was the whole point.
Thanks, what if the manufacturer is the same, but you attempt to flash to a higher model number?
If the chipset is different it's a guaranteed no-go. Though I wouldn't mess with it unless you can hotflash the chip when it goes wrong.
