edifier c6xd problem
33 (0.01/day)
System Name yahia zakaria
Processor i7 3770k
Motherboard asus sabertooth z77
Cooling Nakuta nh d 14
Memory 16 gb ddr3
Video Card(s) zotac gtx 980ti
Storage 2TB HDD , 240GB ssd
Display(s) Benq 23 inch
Audio Device(s) built in relteak
Power Supply ocz 1000 w
i just bought edifier c6xd 5.1 the optical sound doesnt work at all , and if i set to 5.1 the subewwofer and center speaker doesnt work only 3 speaker works with amplifier , i have asus sabertooth with relteake built in sound card . helpppp
Windows 10? Sounds like you need to configure your audio drivers.
Add your system Specs so people can help...
asus sabertooth z77 with relteak built in sound card
and windows 10
i filled the specs , so what ?
Once you plug in the(digital) audio cable does the Audio software pop up asking what device to configure it as? eg Headphone ,speakers, 5.1
If not i suggest you install the latest drivers for you motherboard which should include the software to configure speaker configuration.
Eg.
Also Disable all unused audio devices and make sure Digital output is Default device
Disable monitor Audio if HDMI
Below - in your case you will be using the realtek digital output(optical) so all other can be disabled except for the bottom one.
i already done this before what else ?
there is two speaker
only
have no sound the left speaker and right speaker the other have sound
when i test those works : SL,SR,SUB,C And Those doesnt work : L,R
Not sure who you talking too , what about the audio config i suggested ?
The config on the edifier remote have you checked all levels are up for all speakers
Check that there is no issue with DOA , use the standard auxiliary cord just for a test
The lack of info will be hard to diagnose ,we do not know what you have tried so have to start somewhere.
Use the edit button instead of multiple posts or use the reply button
i managed to get all the speakers working by set in the configuration of relteake 7.1 speaker but when i play music the lift speaker is the only one not working
Hi,I am having problem finding the powersuply for this edifier c6xd 5.1 speaker.I think my one got short circuit.
I want to replace it's power supply or a 3rd party power supply if possible.can anyone please help me with this?
