- Mar 23, 2016
- 4,938 (1.45/day)
Processor | Intel Core i7-13700 PL2 150W |
Motherboard | MSI Z790 Gaming Plus WiFi |
Cooling | Cooler Master Hyper 212 Halo Black |
Memory | G Skill F5-6800J3446F48G 96GB kit |
Video Card(s) | Gigabyte Radeon RX 9070 GAMING OC 16G |
Storage | 970 EVO NVMe 500GB, WD850N 2TB |
Display(s) | Samsung 28” 4K monitor |
Case | Corsair iCUE 4000D RGB AIRFLOW |
Audio Device(s) | EVGA NU Audio, Edifier Bookshelf Speakers R1280 |
Power Supply | TT TOUGHPOWER GF A3 Gold 1050W |
Mouse | Logitech G502 Hero |
Keyboard | Logitech G G413 Silver |
Software | Windows 11 Professional v24H2 |
Support Page said:Windows defines two main policies, Quick removal and Better performance, that control how the system interacts with external storage devices such as USB thumb drives or Thunderbolt-enabled external drives. Beginning in Windows 10 version 1809, the default policy is Quick removal.
In earlier versions of Windows the default policy was Better performance.
You can change the policy setting for each external device, and the policy that you set remains in effect if you disconnect the device and then connect it again to the same computer port.
Important
If you use the Better performance policy, you must use the Safely Remove Hardware process to remove the device. If you remove or disconnect the device without following the safe removal instructions, you risk losing data.
Source: Windows 10, version 1809 and later: Change in default removal policy for external storage media
