- Oct 9, 2007
- 47,670 (7.43/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
EK Water Blocks, Ljubljana based premium water cooling gear manucturer, is proud to introduce the company's first full-board water block for ASRock motherboard - the Z77 Extreme11. EK-FB ASR Z77 Extreme11 water block is a complete liquid cooling solution for ASRock Z77 Extreme11 motherboard. This water blocks directly cools Intel Z77 southbridge (PCH), PLX PEX 8474 PCIe lane splitter, LSI SAS2308 control hub as well as power regulation (VRM / MOSFETs) module. It is a high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber gaskets. The nickel plated brass screw-in standoffs are already preinstalled and allow for easy and trouble-free installation.
EK-FB ASR Z77 Extreme11 comes with the MSRP of 120.95€ (incl. VAT) and is readily available for pre-order through EK Webshop and Partner Reseller Network. The item will start shipping on Tuesday, April 16th 2013.
