- Nov 13, 2007
- 11,368 (1.76/day)
- Austin Texas
System Name | Arrow in the Knee |
Processor | 265KF -50mv, 32 NGU 34 D2D 40 ring |
Motherboard | ASUS PRIME Z890-M |
Cooling | Thermalright Phantom Spirit EVO (Intake) |
Memory | 64GB DDR5 7200 CL34-44-44-44-88 TREFI 65535 |
Video Card(s) | RTX 4090 FE |
Storage | 2TB WD SN850, 4TB WD SN850X |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | Jonsbo Z20 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | DeathadderV2 X Hyperspeed |
Keyboard | Aula F75 cream switches |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
Hey guys, just a quick guide to show how to use NiBiToR to adjust voltages using the voltage register function...
Requirements: GT200 with Voltera voltage regulators (all 65nm).
Disclaimer: DO NOT GO TOO HIGH ON STOCK COOLING This is VERY risky... not only are you flashing, which is risky in itself, but you are also running a ton of additional current through the VRM's. So that's double trouble. Watch those VRM and GPU temps! This will simultaneously pop your VRM's and void your warranty
Get NiBiTor (5.2 or later)
1. Export your bios using GPUtool (best tool ever).
2. Save the bios...
3. Go into the Voltage IC setting
4. Modify the highest register to whatever setting you want (i would stay below 1.36, unless you have LN2, in which case you don't need this guide in the first place)
5. REMEMBER THE SETTING.
6. Go into the Voltage table editor...
7. Modify Entry #4 to the previously set register voltage.
8. Click off the Voltage tab... just to allow the window to refresh
9. Click back on the voltage tab... you should see a blank "extra" setting.
10. Select the set Voltage.
Voila... flash the new bios and your GT200 will run at the set voltage. This let me hit a 24/7 solid overclock of 810Mhz Core and 1620 Shaders... 839Mhz and 1678 for benching
Happy overclocking.
2. Save the bios...
Happy overclocking.
