T0@st
- Mar 7, 2023
- 3,297 (4.02/day)
- South East, UK
Cooling | DeepCool AS500 |
Mouse | Roccat Kone Pro Air |
Introducing our new Endgame Gear EM-C Mousepads—everything about the these new models are designed to provide the utmost best experience for any high-end environment during gaming. A hand picked control surface with low static and high kinetic friction, a stealthy logo that won't get in the way of any mouse movements, a stitching that doesn't rub on your arm and a backing texture that can stick to your table like a suction cup.
Control Surface
This control pad was designed to be the ultimate weapon for tactical FPS games. Excellent accuracy through high dynamic friction on bigger movements combined with low static friction for perfect micro-adjustments. Your aim never felt better.
Japanese Poron
The base is made from premium Japanese 3 mm PORON XSoft which provides a soft feel and comfortable cushioning while offering unrivaled consistency in thickness. The texture on the back provides exceptional grip and non-slip properties.
Sub-Surface Stitching
The edge stitching is flat and thinner than the pad itself providing an unhindered experience to the user and letting the pad lay flatter than conventional stitchings.
Specifications
EM-C: 44.90€ / $49.99
EM-C Plus: 48.90€ / $53.99
Control Surface
Japanese Poron
Specifications
- Dimensions: 490 x 410 x 3 mm / 19.3 x 16.1 x 0.12 in (Standard) or 500 x 500 x 3 mm / 19.7 x 19.7 x 0.12 in (Plus)
- Material: Cloth surface / Poron base
- Color: Black
