Enhanced Sync Problem
f0z
4 (0.01/day)
Hello.
I have Radeon RX 6650XT MECH 2X 8G OC
When Radeon Enhanced Sync is enabled in some games, such as Assassin's Creed Origins, Odyssey, Black Desert Online, the image on the screen freezes completely when opening any interface inside the game. This may occur when opening a map, inventory, main menu, etc. Pressing Alt-Tab helps to avoid this. Please help.
There is no such problem in many other games.
237 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
If enhanced sync is causing the problem then don't use it.
I don't think it's having any benefit in the games you mention.
I think it's more for esports type games, where some people want to run higher FPS than their monitor.
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
What kind of monitor are you using?
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Enhanced Sync is completely broken and very buggy since it was introduced.
they half assed "fixed" it a while ago but it really should not be used.
631 (0.54/day)
Mouse Logitech G903
LG 24GN650-B
Your monitor supports Freesync Premium. Enable that and forget that Enhanced Sync exists, it is redundant with the former enabled.
f0z
4 (0.01/day)
Do I need to disable regular V-Sync with FreeSync?
