eps vs ups...what's gonna be different in my case?
179 (0.05/day)
System Name Bonds silencer
Processor Core i7 5820k
Motherboard Asus sabertooth x99
Cooling Be quiet! Dark rock 3
Memory 4x4gb corsair vengeance(blue)
Video Card(s) Gigabyte Windforce GTX 980 ti
Storage Samsung evo 850 500gb ssd/western digital blue 1tb 7200rpm
Display(s) Asus rog swift pg278q
Case Be quiet! silent base 800 window edition
Audio Device(s) Sound blaster zxr
Power Supply Seasonic platinum 1000w 80+ platinum certified
Mouse Logitech proteus g502
Keyboard Corsair k70 2016 RGB
Hi. So I'm kinda not new to problems regarding my pc(damned build) but let's recapitulate a little:
- my pc was ungrounded and gave anti surge problems.adding a grounded outlet/ updating bios solved this problem but partially.then after a while my pc started having windows boot problem(mbr problem) but it's been solved (there's still a system reserved 500mb partition on my hdd I'm scared of erasing but anyway).right now my pc is giving me some strange shut down/restart...specially when there's some delay btw turning the pc ups and speakers ups (Its actually the reason of this post). Some time windows freeze on startup and others it just don't boot but it's very infrequent...lately it's even slow in shutting down and this is really not a good thing.so to fix the problem I'm getting a new ups:(there's alot of brownouts)my choices are firmly strict:-apc smc1500i for a whoping 500$
-cyberpower 1350va pfc ups available locally for 340 buck.
-shipping cyberpower 1500va from france as its unavailable here.
-now the tricky part: I talked to a shop here and they told me they can get me a eps (emergency power system) for less than the price of the apc. The offer specified the cyberpower cps 1500 PIE 1050w with 2 batteries (equivalent to around 150 ah together ). They said it would last possibly longer and be better. As I have a pfc seasonic platinum who might be doing some problems (I heard from the ups a creepy sound and then everything turned off. After restarting everything was ok...)what do you think it's about? Will a rated <10ms be bad for my pc ? What's the good/bad in each of these propositions.also even if it's a little bit offtopic but any idea why my pc is doing all these error on startup ? Why it's shutting down slowly? Is it because it's cracked entreprise win 10 I have? (Kmspico but I'm not happy of this...trying to get another windows install but it's a little bit hard to change windows to windows pro without formatting...)is it possible to have win 10 pro and entreprise on 2 différend ssd on the same pc?.I hope I've not been too ....... but I think there's some link btw all of those little problems I'm having.thanks.
On the hardware end, it sounds more like you need a pure sinewave device than you need battery backup. Both options claim to deliver that,in which case the cheaper option would be better.
On the software end... why are you cracking a virtually free software? We still have a month and a half within the free upgrade window
Offer ends 7/29/2016
So copy your files off, upgrade to genuine (either directly or via a clean install of an old copy of vista, 7, 8.0, or 8.1), and then copy your files back and reinstall your programs.
You're the guy who shows up at the free sample display, swipes one, and then runs away shouting "you'll never catch me alive!" ... dude, it was free. :rolleyes:
I got a free win10 pro key from a giveaway at tpu bit the thing is I don't know how to remove the windows 10 enterprise and put this without loosing the data contained on it.
you don't now how to copy files off a drive and then re-install? Like seriously C:\Users\"your username"\ copy that entire thing off of there and onto an external drive or a secondary drive. Then reinstall windows with a legit key. Use the exact same username. Activate it, install drivers, reinstall programs. Then copy the user profile from the old install over top of the new user profile of the same name.
Done.
