Ethernet problems on new motherboard.
Status
Not open for further replies.
1,227 (0.19/day)
United Kingdom
Processor Intel 10 Core i9 10900K Comet Lake CPU/Processor
Motherboard Gigabyte Intel Z490 AORUS MASTER ATX Motherboard
Cooling Noctua Intel/AMD NH-D15 Silent CPU Cooler
Memory Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Video Card(s) Zotac NVIDIA GeForce RTX 3080 8GB AMP! Extreme Turing Graphics Card
Storage Samsung 970 EVO PLUS 500GB M.2, Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
Display(s) ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor, Sony Bravia 49" 4k uhd tv
Case NZXT Phantom 410 Black Orange Special Edition
Audio Device(s) Sound BlasterX AE 5 RGB PCIe Gaming Soundcard
Power Supply Corsair RM1000
Mouse Roccat ROC-11-812 Kone EMP Max Performance Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Keyboard Roccat isku/ fx
9,804 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
What version of Windows ?
dorsetknob
9,106 (1.24/day)
does it Show in Bios and is it enabled in Bios
1,227 (0.19/day)
United Kingdom
It is Windows 10 64bit, Andi will check the bios.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
https://www.asus.com/us/support/FAQ/1031868/
As stupid as it may sound, I've also had some luck when installing the AI suite that is included with certain motherboards from some manufacturers. Of course it will have trouble doing much if it can't connect to the Internet. But you may be able to boot into the bios with the ethernet connected , some newer motherboards offer a function where theyll search for updates or drivers from inside the bios, I don't know whether or not the driver needs to be installed yet or not , but I would assume that there's already some kind of ethernet software on the motherboard chip, unless im mistaken as to how that function works.
Hotfix for TH1: KB 3140745 32bit: Windows10.0-KB3140745-x86.msu
64bit: Windows10.0-KB3140745-x64.msu
Hotfix for TH2: KB 3140743 32bit: hotfix for Win10 TH2 x32
64bit: hotfix for Win10 TH2 x64 (548MB)
Also, here is the Intel Ethernet driver as far as i can tell
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10
1,227 (0.19/day)
United Kingdom
Don't ask me what happened, tried the disc once more and walked off when it was installing and when I went back to try the stuff you had advised the b****y thing had connected. The only difference is I installed the realtek sound drivers but I don't know what difference that could make if any. regards and thanks for the prompt help.
9,804 (3.23/day)
Case Phanteks NV7
You shouldn't even need to install anything , Windows already gets everything done anyway.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
I haven't built one of these confangled newer systems yet, but for my asrock motherboards ,I would have to install the lan driver ,otherwise I couldn't get online for windows to update. But that may very well not be the case any longer
1,227 (0.19/day)
United Kingdom
I couldn't get online until I installed the lan drivers, now I'm online windows can update it all.
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
My "guess" is somewhere in the middle of everything, your computer rebooted. This "set" settings and told your router to assign an IP address. From there, you were good to go.
I note Ethernet is a very mature, stable, robust, communication, industry "standard". Ethernet devices don't need any special drivers. That's why I think my "guess" is right.
44,288 (6.80/day)
Not all controller drivers are the same man.
22,212 (3.44/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK)
Case Thermaltake Core X31
Depends on the ethernet controller and whether or not the driver ships with windows.
1,227 (0.19/day)
United Kingdom
I had a lot of problems getting the lan drivers to install of the disc, I ticked them to install about 3 times but they didn't want to install. I must admit didn't have these problems with the Gigabyte boards.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
Don't use the disk. Just use the chipset driver installer from Intel which should cover the network interfaces.
44,288 (6.80/day)
Sometimes you have to manually install them. dude if you have anyn other issues post them here
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Sorry but that is not true. If it were, how can a computer boot into "Safe Mode with networking"? How can you even install Windows since networking is setup before installation is complete? How could you install Linux? How could you go out and get the controller's drivers if they were needed?
All Windows since (pretty sure) Windows 95 supported Ethernet natively.
Again, Ethernet is an industry standard. The ONLY reason there would be special drivers is if the NIC supported extra features (that most like no user ever need).
FTR, and before someone says it, we never, as in NEVER EVER use the disk that comes with motherboards during builds. Never! Why? Because odds are that disk is already 6 months old or even a year or older. So on all our builds, we visit the motherboard's website and check for new drivers. How could we do that if the motherboard's Ethernet controller needed special drivers for Windows?
We couldn't.
501 (0.14/day)
Skopje, Macedonia
System Name The Tesseract Cube
Processor AMD Ryzen 5 3600
Motherboard MSI X570A-PRO
Cooling DeepCool Maelstrom 240mm, 2 X DeepCool TF120S (radiator fans), 4 X DeepCool RF120 (case fans)
Memory 2 x 16gb Kingston HyperX 3200mhz
Video Card(s) Sapphire Radeon RX 6800 Nitro + 16GB
Storage Corsair MP400 G3 1TB, Western Digital Caviar Blue 1TB
Display(s) MSI MAG241C Full HD, 144hz FreeSync
Case DeepCool Matrexx 55
Audio Device(s) MB Integrated, Sound Blaster Play 3 (Headset)
Power Supply Corsair CX650M Modular 80+ Bronze
Mouse Corsair Dark Core Pro Wirless RGB
Keyboard MSI GK30 Mecha-Membrane
Benchmark Scores CPUZ: Single Thread - 510 Multi Thread - 4.050 Cinebench R20: CPU - 3 500 score
That is why smartphones exist.
PC Hacks 101 LOL
44,288 (6.80/day)
We couldn't.
My DFI lanparty nforce to ultra be required a ethernet driver to be installed by the manufacturer in order for it to access Internet the one in Windows was not compatible
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Same with my Gigabyte Z270 Motherboard both nics need drivers installed or you get nada
Installing drivers is a pain sometimes. It doesn't always go well. Ive had so many installs where I had to reinstall the drivers because of a cluster f
1,227 (0.19/day)
United Kingdom
finally got it and all windows updates in used the lan drivers from Asus site it was still a bit fiddly but I know what to do now.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Wow, I use Gigabyte boards all the time and didn't need to. I know for a fact, natively Windows support DHCP networking. I can only conclude those boards use non-standard devices.
My apologies for assuming otherwise.
44,288 (6.80/day)
I typically find out what chip is used for it then get the drivers from the maker directly, asus doesnt update their drivers soon enough
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
And I have a different philosophy as I have seen where motherboard (and graphics card) maker modify the drivers to make them proprietary. So I always recommend getting drivers from the board/card makers instead.
44,288 (6.80/day)
Haven't had an issue with realtek drivers or AMD chipset drivers directly from the site.
dorsetknob
9,106 (1.24/day)
Manufacture,s supply a Drivers disk ( :)with working Drivers) for initall install.
Nothing wrong in using them for in initial ( offline install ) and later when online update as you see fit
Status
