EVGA Precision scan errors
7 (0.01/day)
Processor Ryzen 5 3600
Motherboard Asus Prime B350 Plus
Cooling Zigmatek block
Memory 2x8 16 GB DDR4 2400 MHz
Video Card(s) EVGA GTX 1660 Super SC Ultra
Storage PNY CS 900
Display(s) ASUS VX229
Case Phanteks PH-EC400ATG_DBK
Power Supply High Power +80 Element Bronze 600 Watt
Mouse Logi
Keyboard Logi
Software Windows 11 Insider Beta
Hello. When I install the VBIOS on my EVGA GTX 1660 SUPER SC ULTRA GAMING graphics card, the Precision X1 scan gives an error in the test.
There is no problem with the original VBIOS. I wanted to share the original VBIOS version that I backed up earlier and that you don't have. Thanks.
Just a tip, you can submit your VBIOS to the TPU database directly from GPU-Z, that way it will be available as a download for everyone directly through the site, at first through unverified uploads but eventually it will get approved.
As for your case, someone already uploaded the BIOS that your card has to the database, here you go:
Thanks for the answer. But why is it not on the list!
Because you are looking at the verified upload section :)
On the filter where it says "NVIDIA" choose "Unverified uploads" instead. The BIOSes in that section haven't been checked by TPU staff, so they may or may not work - easy to spot if there's any glaring issue thanks to the BIOS summary, though. If the size adds up and the information box is concise, it's probably safe to flash, especially if you have dual BIOS support.
The VBIOS upload was successful. :)
I understand. I have uploaded the file. Thanks again.
