Ex-mining GPU question!
65 (0.08/day)
Hello everyone
I have purchased an ex-mining Sapphire Nitro RX480 8GB graphics card from an eBay seller on a for parts or not working basis.
The card was in a sorry state when I received it, it was filthy and quite corroded. Since then, I have cleaned it up and refurbished it with new thermal pads and thermal paste. I have also flashed the original gaming bios on it as the previous owner had a mining bios on it that prevented it from working correctly.
The issue is, despite my efforts, the card will freeze the system when running a benchmark or a game. When cold, it might run for a bit longer, but it will still (hard) freeze the system after a while.
So the most likely scenario is that the card has deteriorated from prolonged mining use to a point it cannot support the stock clocks any more. I'm thinking to lower the core / memory clocks in an attempt to rectify the issue but perhaps a (modified) bios would be a better solution? What do you think? The card has dual bios so there is no risk of bricking it.
Any help or advice is highly appreciated.
Best
Ppanickk
3,948 (4.95/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
Well, if we don't know how it behaves downclocked we also don't know if it makes sense to downclock it and render it permanent via BIOS.
Are all temperatures in check? Got a technician to test resistances, voltages, etc?
Since it's a mining-worn GPU my main suspicion falls upon two things, VRAM and VRM. Test ~1.7 (6.8 effective) GHz VRAM first, lower power limit (-20%) second.
If that's VRAM then just run it downclocked and call it a day. If it's VRM it could make sense to replace it if you got compatible spares in OK condition in a close enough proximity.
2,839 (1.29/day)
PNW, USA
System Name Metalia
Processor AMD Ryzen 7 5800X3D
Memory 2x32GB DDR4-3600
If it were my card, it'd be getting a bake.
That sounds like cold solder joints.
Or,
'worn out' power components, no longer operating within spec. Which, isn't worth 'fixing'.
2,200 (0.35/day)
System Name Ryzen7700
Processor AMD Ryzen 7 7700
Motherboard Asus ROG STRIX B650E-F GAMING WIFI
Cooling NZXT Kraken X62
Memory Patriot Viper Venom PVV532G700C32K (32GB @ 6000CL28)
Video Card(s) AMD Radeon RX 6800XT Midnight Black
The VRM is busted and needs to be replaced. A temporary fix would be to add thermal pads on the backside of the VRM so heat can be absorbed by the backplate.
https://www.reddit.com/r/Amd/comments/5sqog2
1,155 (0.69/day)
System Name Laptop ASUS TUF F15 | Desktop 1 | Desktop 2
Processor Intel Core i7-11800H | Intel Core i5-14600K@135W | Intel Core i3-10100
Motherboard ASUS FX506HC | Gigabyte B660M DS3H DDR4 | MSI MAG B560M Bazooka
Cooling Laptop built-in cooling lol | Thermalright Assassin Spirit w/ BeQuiet Shadow Wings fan| Stock Copper
Memory 24 GB @ 3200 | 32 GB @ 3733 | 16 GB @ 3200
Video Card(s) Nvidia RTX 3050 Mobile 4GB | Nvidia GTX 1650 | Nvidia GTX 960 2 GB
Storage Adata XPG SX8200 Pro 512 GB | Samsung M2 SSD 256 GB & 1 TB 2.5" HDD @ 7200| SSD 250 GB & SSD 240 GB
Display(s) Laptop built-in 144 Hz FHD screen | Dell 27" WQHD @ 75 Hz & 49" TV FHD | Samsung 32" TV FHD
Case It's a laptop, it doesn't need case lmfao | Deepcool Mattrexx 55 MESH | Aerocool Cylon PRO
Audio Device(s) laptop built in audio | Logitech 2.1 speakers | Logitech stereo speakers
Power Supply ASUS 180W PSU | SeaSonic Focus GX-550 | SeaSonic M12II EVO 520W
Mouse Logitech G604 | Corsair Harpoon wired mouse| Logitech G305
Keyboard Laptop built-in keyboard |Razer Blackwidow | Steelseries APEX 7 TKL
VR HMD Quest 2 sold out and don't need VR anymore lol
Software Windows 10 Enterprise 20H2 | Windows 10 Enterprise 20H2 & Ubuntu Mate 24.04.2| Windows 11 24H2 LTSC
Benchmark Scores good enough
Hello everyone
Best
Ppanickk
advice 1: don't buy very old gpus which are ex-mining era. Potential scam, and potential brick.
advice 2: ex-mining purchases this time MUST start with GTX 16, RTX 20 series, RX 5*** series. Though, Nvidias might be in better condition as most a way cooler lol.
3,948 (4.95/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
RTX 20 series
Non-Super variants excluded. They are much more worn-out.
RX 5*** series
I'd rather not. Their behaviour under light loads is something... else.
Polaris GPUs, though, are very tough nuts to crack. My RX 480 still works and handles some OC despite it being ancient and used in mining. Their most major disadvantage is that they are weak and obsolete by today's standards.
1,155 (0.69/day)
was happy to get RX 5700 and now sold it to friend who is also a happy user of it...
65 (0.08/day)
Thanks for responding.
I do have one question about the power limit and the rationale of lowering it.
Initially, I was thinking to try the opposite really. If the stock core / memory clocks are unsustainable, perhaps with more power they can be sustained, no?
Or,
A bake is an option but there is also the risk of completely bricking the card. Happened to me a few times.
That would suck really as I am not good with the soldering iron. It is on my to do list though, one day!
I got this for cheap just for the sake of playing with it. If it does end up working (doubtful), I will use it in one of my systems. If it doesn't, no harm is done.
ir_cow
5,022 (0.83/day)
USA
I think it could be two things. 1: A Mosfets is going bad. Once up to temp it drops voltage causing the core to crash 2: The GPU been abused and requires more voltage for the same clocks. Could be both together.
On a side rant. It sucks you bought this card. Just gives miners more profit and encourages them to continue this practice.
2,200 (0.35/day)
Its not abuse but poor mosfet quality. Friend of mine had a RX480 from Sapphire with the same issue. It occurred at the end of the warranty.
He was the first owner of the card and didn't sent the card for repairs because it only happend in one game....one year outside the warranty it got worse :banghead:
The thermal pads mod for the VRM did the job for some time until a mosfet died
