Excel 2007, highlighting or bolding a single gridline
EastCoasthandle
6,885 (0.93/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
Hello,
I need some help. I am creating a chart using Excel 2007 and, I am trying to figure out a way to highlight, bold or glow a particular gridline using Excel 2007. I want to place emphasis on a particular frame rate by adjusting it's horizontal gridline. However, the problem is that Excel 2007 will not allow you to mouse click on a particular grid :shadedshu.
If I recall correctly Excel 2003 allowed me to mouse click on the grid of choice and make changes to it as I see fit. With Excel 2007 if you mouse click on 1 grid all the grids are chosen, thus the problem. I've been looking around but I do not know the technical term used for this.
As you can see from the example above all the gridlines are highlighted (called Glow in Excel 2007). All I want to do is highlight just 1 (maybe 2 of them). Is there a way to do this?
To further clarify I want to be able to change the gridline to look something like this:
Where in this example the max FPS uses a green gridline while the min uses a red gridline.
I'm not familiar with 2007 but have you tried Ctrl+click?
Thanks for the advice erocker but it doesn't work.
Edit Misunderstood, let me keep playing
