External HDD problems
2,707 (0.40/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Hi!
I have a Seagate Expansion External Drive 2TB and have problems with it.
http://www.seagate.com/docs/pdf/datasheet/disc/ds_ext_desktop.pdf
First: When restarting my PC or rebooting it takes sometime forever but instantly happens if i disconnect the external drive power.
Secondly: My PC loses the drive sometimes and i have to disconnect and reconnect power to it.
Maybe it is because i use a lot of sleep mode on the PC.
What could case the problems? Whats the solution?
Greez Lauri
How is your USB ports setup for power save? OS or BIOS?
Have you tried a different USB port? Different USB HDD?
Did you have boot to USB devices enabled?
How old is it? Can you run a Check Disk on the drive? Could be a failing controller, could be a failing drive...I would start by checking for errors. I suppose if it wont' stay connected for that much, try a different port. if that fails, take the HDD out of the case and hope it's just a SATA connection that you can then just install to your PC, then test using CHKDSK and get a SMART utility such as Crystal Disk Info, Speccy, etc....and see if the drive is bad...if not...get a cheap USB2/3 housing. Or get a new USB HDD if it fails.
:toast:
My USB ports are not set up for power save - i didnt do nothing other than connect the drive.
Where do i change those power save settings?
I changed the USB power saving options and now the drive lets me shut down the PC without waiting forever :)
