External HDD w/ USB3.0 and eSATA interfaces?
111 (0.02/day)
NYC
System Name POWERHOUSE
Processor Core i5 760 @ 4013 Mhz
Motherboard ASUS P7P55D-E LX
Cooling Sunbeamtech Core-Contact Freezer 120mm
Memory Corsair CMX8GX3M2A1600C9
Video Card(s) ASUS HD6950 w/ASUS 6970 BIOS
Storage 128GB Crucial RealSSD C300 2.5-inch SATA 6GB/s
Display(s) ASUS VW246D
Case ULTRA Aluminous ATX
Power Supply Corsair tx750w
Software Windows 7 x64 Ultimate
I'm looking to buy a new external HDD in the 2TB flavor. To fit my needs, I have been looking all over for a drive that has both USB 3.0 and eSATA.
Seems to be nonexistent tho. Anyone know of one that has both?
Thanks :rockout:
Why do you want USB3 if you're going to be using eSATA?
I will be using it on multiple systems. At home I will be using eSATA for sure.
When I use it on other systems I want the ability to use USB. Almost everyone has a USB 2.0 port, and if the user has USB3.0 I'd obviously like to utilize it.
There are plenty of drives with USB2.0/eSATA and if I cant find a USB3.0/eSATA drive I'll have to settle I guess.
Hmm.. The only thing I've been able to find are external drive bays that have USB3.0 & eSATA.
But then you'll have to carry around the big hunk of enclosure. xD
I'm surprised there isn't a single-HDD bay external enclosure that's more portable.
But this is what I found: Mediasonic HF2-SU3S2 3.5" USB3.0 & eSATA 4 Bay Ext...
Pretty big and expensive though. :/
Yea, someone just pointed me towards one. I have been looking for a drive/enclosure combo this whole time and didnt think to just find a damn enclosure with USB3.0/eSATA then just get a drive for it! :banghead:
Thanks man.
I am looking for the same thing. I have USB3 on some machines and eSATA on others - would like a single compatible enclosure - preferably 2.5 inch to take in the field. There were a ton of USB 2.0 and eSATA enclosures.
I have to give credit to someone on another forum that found this for me. I'm not sure I would have ever found it... It's like hidden in Newegg (doesnt come up in search and is cataloged oddly) and Google didnt help much at all trying to find a USB3.0/eSATA external enclosure. I literally searched for hours.
It's exactly what I wanted. Been using it for 3 days already, works great with both USB3.0 and eSATA. Solid construction. Comes with eSATA and USB3.0 cables! I cant really say anything bad about it, except I wish it came in a black color.
EDIT: If you get it, beware the HDD mounting screws it comes with. I am pretty sure the sled I installed my HDD in is going to be permanent... lol. The screws didnt go in so well and arent backing out. I could probably get them out, but I think I stripped the drives mounting holes a little. This may be the drives fault as well tho... Just putting that out there.
SANS DIGITAL MS1UTP 3.5" SATA Hard Drive to SuperS...
Also, this is the drive I paired it with:
SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB Cac...
