Extra atx socket on mobo.
1,227 (0.19/day)
United Kingdom
Processor Intel 10 Core i9 10900K Comet Lake CPU/Processor
Motherboard Gigabyte Intel Z490 AORUS MASTER ATX Motherboard
Cooling Noctua Intel/AMD NH-D15 Silent CPU Cooler
Memory Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Video Card(s) Zotac NVIDIA GeForce RTX 3080 8GB AMP! Extreme Turing Graphics Card
Storage Samsung 970 EVO PLUS 500GB M.2, Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
Display(s) ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor, Sony Bravia 49" 4k uhd tv
Case NZXT Phantom 410 Black Orange Special Edition
Audio Device(s) Sound BlasterX AE 5 RGB PCIe Gaming Soundcard
Power Supply Corsair RM1000
Mouse Roccat ROC-11-812 Kone EMP Max Performance Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Keyboard Roccat isku/ fx
Hi I am just in the middle of replacing the motherboard in my grand daughters system with new motherboard,
https://www.scan.co.uk/products/gig...triple-m2-2-way-sli-3-way-crossfire-wifi-usb3.
I notice there is an extra 4 pin tax connector beside the 8 pin one I cannot find a lead for it is it needed.
This is here system,
Zalman Z3 Plus ATX/M-ATX Tower Case - Black
Intel Core i5 8600K Unlocked Coffee Lake Desktop Processor.
Cooler Master Hyper TX3 EVO CPU Cooler
AORUS Intel Z390 ULTRA 9th Gen ATX Motherboard
Samsung 960Evo M.2 NVMe
Crucial 480gb ssd.
Corsair 8GB DDR4 Vengeance LPX 3000MHz Memory
Zotac NVIDIA GeForce GTX 1060 AMP! Edition 6GB Graphics card
Coolermaster VS-Series 550W Semi Modular 80+ Gold Power Supply
Liteon Ihas324 24x Dvd±rw (dual ±r)/ram Sata Drive
Windows 10 Home 64bit
Microsoft Wired Keyboard 600 Black - USB
Kensington Mouse-in-a-Box - optical - wired - USB - black
Xenta 2.1 Speaker System
That looks like a P4 connector, the other looks like an EPS 12 volt
Do l need it.
God damn why do you need a 250 Pound board
There is not one with the power supply
Upgrade to bigger psu, of course you could try running without it, run p95 and a gpu test like furmark at the same time.
Do not suggest furmark
Do not suggest I do not suggest furmark. It is a gpu stress test and for a system stability check it is more than adequate.
Furmark can brick cards if the user is not careful enough.
Oh jesus...
1.) You don't need a bigger PSU for that build.
2.) The 4-pin is completely optional and is used for extreme overclocing.
3.) Furmark hasn't been a good GPU stress test in years. The GPU drivers detect it as a power virus and lower clocks and power limit when it is run. Meaning the GPU is never actually stressed, defeating the point of a stress test. Use loops of Heaven or Superposition.
The manual says you need a 500w power connection to the board, or it may not work.
IDK if you really need that, but at 7A/pin, 4 pins are 336W, and 6 pins are 504W, so that goes with the manual, in that you need both connectors connected to support what they say you need.
I's Guess that's for overclocking, but IDK.
If your CPU needs more than 336W, use both.
If it works without it, and crashes when you try to OC, that's your problem.
Forget about the optional 4 pin, you're never gonna come even close to maxing out the 8 pin with an 8600K.. If you're pushing a 9900K under liquid nitrogen, then yeah, maybe.
The power supply you already have is absolutely fine, no need to upgrade. 550W is PLENTY for an 8600K + GTX1060.
I suspected his granddaughter is der8auer.
In some rare cases this optional connector maybe mandatory, at least my Supermicro C2SBX will not power on with only one plugged in.
