Fan curves don't work as expected?
3,471 (0.61/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
In addition to my stupid graphic card noise, I can't seem to be able to configure the system fans.
Maybe I misunderstood how the fan curves work - you tell me.
CPU fan
case fan
I thought the points work so that once given temperature is reached, the fan switches to higher speed as defined.
But that's not the case.
I let BF4 run in the background, but the fans are still at their lowest settings. The case fan (chassis 3) for example should spin at ~900 rpm, which is more or less the 45% I set, not 700.
Can anyone tell me what the hell is wrong here?
Someone has just told me the board/CPU uses the CPU and not CPU package sensor for fan settings, which is bad, because that sensor reports significantly lower temperatures.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Did you take into account the 12second delay till it actually ramps up?
3,471 (0.61/day)
Czech republic
That's what I added later on, that's not the problem. Also I keep the game running in the background so the CPU reaches the max temperature.
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
I haven't seen boards using package temp. What's the problem tailoring the curve according to right CPU temperature?
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I dont like BIOS fan curves so I use AfterBurner. Not sure how many 'points' there are in the average BIOS curve, but in AB I use 8.
3,471 (0.61/day)
Czech republic
Because there is no direct relationship between the two temperatures. I don't know what to set the curve to.
Maybe you don't understand.
The motherboard reports (and shows in the BIOS obviously) two CPU temperatures: "CPU" and "CPU package". "CPU" is some bullshit. "CPU package" is the real temperature.
BUT the motherboard uses the "CPU" for FAN settings, not the real one, which makes it impossible to set the curves properly, because I have no idea what the bogus temperatures would be like.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
45% duty cycle doesn't equal 45% of maximum RPM.
3,471 (0.61/day)
Czech republic
What is it then?
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
What is it then?
It is what it is, it's a logarithmic curve, volts in to rpm are not a linear curve I think.
Initially it won't spin at all upto 3-6v then it starts so non linear.
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
What is it then?
It is PWM signal level. Mathematically it represents a logarithmic curve. Usually x = a^y + b. It ain't very curved.
Basically just do the graph based on CPU temps and call it a day. The basis for that could be that the temp data is gathered from external LPC controller what communicates with the CPU and it does manage the fans, it is a more robust solution.
In windows you access the internal procesor data, so you get more sensor data so don't mix up things.
Just adapt... it ain't that hard.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
What about using SpeedFan
3,471 (0.61/day)
Czech republic
Why is nothing ever simple? I know nothing about math (and what I knew I forgot 20 years ago, thankfully) and my head already looks like a baloon.
When I did the grap based on CPU temps it didn't work, that's what I described in the original post. Do you not get it? I know the real temps, but I don't know the bogus temps equivalents the fan controller uses, so I can't configure it.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Best thing to do is to avoid using BIOS fan curves, it is annoying.
Like @DeathtoGnomes i used AfterBurner, now i am using iCUE and have it set this way: from 20c to 30c the fans runs at 800rpm, at 35c they run 900rpm, at 40c 1250rpm and 45c+ 1500rpm
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
If you are sure those are PWM fans you have there... you can experiment and switch to QFAN voltage regulated mode. Revert the delays you put there also. Use CPU-Z bench for quick lookup if it ramps up.
trickson
OH, I have such a headache
7,595 (1.02/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
I use Asus fan expert.
I am not an expert on fan controls I normally let the bios do this automatically but now that there is this fan expert app well it's brainless set and forget lol.
Any way I really would like to know why they have 2 different CPU temp's now. This is stupid!
Why can't they just give us a fing temp reading to go by and stop all the confusion?
Isn't After burner some MSI program? I thought it was like "MSI After burner" or some shit like that..
At any rate I would not use that POS APP I have been around MANY years and every time I used that POS program in the past all it did was give me a head ache. LOL.
Not saying it don't work for you all just never liked the user interface nor the way it interfaced with my system. Causing crashes and lockups.
My advice is to see if the MB you have has a built in AI suite. or some thing like it.
3,471 (0.61/day)
Czech republic
Doesn't that do exactly the same thing as what you can do from within the BIOS?
Oh and another thing that makes all this even bigger problem that I have just noticed: the inside of the case heats up before the CPU hits any significant temperature because of the graphic card, which in turn eventually spins its fans faster than it could have.
The CPU fan itself might be okayish, but there's no good way to control the case fan. It can be based on CPU temperature, chipset, and something else, none of which really help. I can't set the lowest speed (which would help in this case) it too high because it produces really annoying noise due to pushing air through the case grille. Unfortunately there's likely no solution for this part of the problem, because the fans are completely separate.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Yes it is.
I assume it does :rolleyes:only thing that changes is that you download it from the Asus website and install it so you dont need to go into the Bios :sleep:
trickson
7,595 (1.02/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Yes and NO. See you have to be in the bios to in order to adjust the fans here you are in the real working environment.
It sounds like you need a better case with more air flow and a new After market ( if you do not already ) CPU cooler.
You have lots going on and you will need to start with a case first.
3,471 (0.61/day)
Czech republic
The case is perfectly fine and so is the cooler.
The airflow is directly related to the fan speed.
trickson
7,595 (1.02/day)
Planet Earth.
Cooling Noctua
Mouse Optical
No not if the video card is heating up the inside of the case (as well as everything else). But Hey if you say so I am dipping out take care good luck.
3,471 (0.61/day)
Czech republic
Feel free to inspect my system specs before coming to wrong conclusions.
The physical dimensions and layout of a case don't CREATE any airflow.
175 (0.05/day)
Finland
System Name Amadeus
Processor AMD Ryzen 9 5900X
Motherboard Asus X570-F
Cooling EK CR360
Memory 32Gb DDR4 @3600MHz
Video Card(s) RTX 3080 10Gb
Storage 1Tb NVMe, 2Tb NVMe, 2x 2Tb USB HDD
Display(s) Samsung C32JG50
Audio Device(s) SoundBlaster G6 with Sennheiser Game One
Power Supply EVGA G2 750W
Mouse Logitech G603
Keyboard SteelSeries Apex M500
Benchmark Scores TimeSpy: 16 201
I'm having a similar problem, did you find solution?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
are you not able to set these curves using your motherboards fan control?
2,540 (0.47/day)
Stop that step up. It is hysteresis, you are setting a 3.6 second latency which kills the benefit of having minute response to temperature changes.
You might be running two overriding monitoring utilities which disrupt one another from accessing the gpu fan curve.
You might be running too wide q-fan bios fan control ranges. If the range is all the way, it controls 1000-5500rpm over the same 100% spectrum which kills variability for your hearing deficit sake. You need to go to your bios, select a narrower qfan range(like 20-40% I forgot mine) such that when windows takes over and the ranges are defined on qfan's limits, 100% does not cause deafness and 0% does not just run idle and actually move some air without being particularly loud.
Also, if you let the fans idle, the air volume will start heating and increase your case temperature until ramping the fans won't be able to effectively dissipate the air quickly. Always keep more air circulation than not.
One last item, if you want to control your gpu fan, just open up your monitoring utility, mark each percentile's rpm and form your own linear fan ramp curve. You'd be surprised how close and far each percentile gets, somewhere around 40%, the fan velocity was most divergent and the individual 10 fan curve spots got the closest there.
130 (0.05/day)
Dubai, UAE
System Name The Nomad
Processor Ryzen 5 5600
Motherboard Asrock B550M Phantom Gaming ITX
Cooling Arctic Liquid Freezer II 240
Memory 2x8GB Patriot 4400MHz DDR4
Video Card(s) MSI RX 5700 Evoke OC w/ Arctic Accelero Xtreme IV
Storage 1TB A-Data SX8200Pro, 4TB WD Blue HDD
Display(s) Gigabyte M27Q 27"
Case Coolermaster NR200P
Audio Device(s) Epos H6 Pro
Power Supply Corsair SF600
Keyboard Logitech G815
