- Aug 11, 2011
- 393 (0.08/day)
- Denmark
System Name | Coming up in september |
Hello, I've been browsing 120mm fans from caseking.de, and found a couple of candidates, but I need help deciding on the fan, note that the price difference is negligible and it will be used for overclocking approximately to 4.5ghz
CPU: 2500k
Cooler:Corsair H60
Case:Lian Li PC-Q08
Fans(PWM not needed, I will try to make it run at its highest RPM):
-Be Quiet Shadow Wings High-Speed: http://www.caseking.de/shop/catalog...ter-Shadow-Wings-High-Speed-120mm::17620.html
-Alpenföhn Wing Boost Plus: http://www.caseking.de/shop/catalog...oost-Plus-PWM-Luefter-black-white::17942.html
-Akasa Apache: http://www.caseking.de/shop/catalog/Luefter/Akasa/Akasa-Apache-120mm-PWM-Fan-black::13872.html
-Gentle Typhoon 1850 RPM (another shop)
Build quality and reliability also matters
Thanks in advance
CPU: 2500k
Cooler:Corsair H60
Case:Lian Li PC-Q08
Thanks in advance
