Feature suggestions - move to proper menus, add Options window
1,108 (0.21/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
Suggestions:
1) Remove main menus from top left menu (system menu) and move them to a standard Windows menu, at the top.
Leave the 6 system menu items (Restore --- Close) in system menu, move all the rest to that standard main menu. The main menu can be auto-hidable - pressing Alt key to invoke it or hide it, similar to the way IE11 menus and many Windows 10 built-in apps' menus work.
2) And/or, add an Options menu or button, which would invoke a separate screen with GPU-Z Options, similar to how most Windows apps work.
Most Windows apps have a separate Options screen, which GPU-Z lacks - one should be added.
Thanks in advance for listening!
Then you need to tell people the magic "alt key shows menu shortcut"
a separate options window could be an option worth exploring
Bumping this thread - hope for a proper Options window in the coming new version(s). :)
EDIT: With more options/settings coming in new GPU-Z versions, the need for a proper separate Options window increases.
OK, please add a User Guide/Manual then! :)
It could be in Adobe PDF or MS CHM format. ;) Or maybe HTML will work too.
Some of the settings and their location are not quite clear now, so having a ~short~ User Guide would be nice.
