first time builder and pc (EU)
iivari
4 (0.03/day)
Heya
So for a long time I used a laptop for gaming and school and couldn't afford to own a pc becasue my family moved around a lot. Now that I've settled in on a place that I'll be living in quite a while and in conjunction with my four year old laptop bricking this week, I've decided I want a gaming PC. The goal of this PC is to get 200+ fps on 1080p on Marvel Rivals and Fortnite during the intensive parts i.e during a team fight or when there's a lot of building going on. My thought process behind picking the parts was trying to find the most bang for your buck option that totalled under 1400€ because my friend told me the sweetspot for budgeting is between 1200€-1400€.
I made this list but I'm not sure if I should spend more on a better CPU cus I heard Rivals and Fortnite especially are CPU bound. I'm torn between the 7700xt and 7800xt and I'm really not sure about the motherboard and psu.
PCPartPicker Part List
CPU: AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor (€153.00)
CPU Cooler: ARCTIC Freezer 36 CPU Cooler (€25.00)
Motherboard: ASRock B650 Steel Legend WiFi ATX AM5 Motherboard (€199.00 @ Megekko)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€109.90 @ Amazon Netherlands)
Storage: Kingston NV3 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€54.90 @ Megekko)
Video Card: Gigabyte GAMING OC Radeon RX 7700 XT 12 GB Video Card (€429.00 @ Amazon Netherlands)
Case: Lian Li Lancool 207 ATX Mid Tower Case (€85.85 @ Alternate)
Power Supply: Super Flower Leadex III Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply (€90.00)
Total: €1146.65
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2024-12-23 15:46 CET+0100
Add a 120mm rear exhaust fan to that case, cut down on your motherboard and use the savings to size up on your SSD. Also make sure that case will fit your power supply. I read somewhere that a 150mm power supply is what fits into that case but hopefully someone here will know better.
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (€159.00 @ Megekko)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€115.48 @ Azerty)
Case Fan: *ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan (€7.99 @ Amazon Netherlands)
Total: €1175.22
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-12-24 00:01 CET+0100
If that psu doesn't fit then here's two cases to have a look at.
Case: *Montech AIR 903 BASE ATX Mid Tower Case (€71.90 @ Megekko)
Total: €71.90
Generated by PCPartPicker 2024-12-24 00:07 CET+0100
Case: *Montech AIR 903 MAX ATX Mid Tower Case (€85.85 @ Alternate)
Total: €85.85
Generated by PCPartPicker 2024-12-24 00:08 CET+0100
Update: I found a less expensive motherboard and fit in a 7800XT
CPU: AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor (€155.00)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard (€144.99 @ Amazon Netherlands)
Video Card: ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card (€489.00 @ Amazon Netherlands)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€94.90 @ Amazon Netherlands)
Total: €1159.54
Generated by PCPartPicker 2024-12-24 00:14 CET+0100
I'm going to sound nooby but I need you to explain the reason for adding the rear fan. Are the fans that come with the case good enough?
Yea I read the same thing from GamersNexus's review on it. I was also considering the Montech XR and 903.
An alternative power supply I'd consider:
Be quiet! Pure Power 12 M 750W
I think going at least with the 7800xt is a good idea for what you're trying to play.
That case is probably fine, but the extra fan they suggested is because it doesn't come with an exhaust fan. It has two front fans, which you'll want to keep there to make sure plenty of fresh air is brought in. The exhaust just tries to help make sure the heated air gets out and putting the exhaust on the top/back helps direct where that mostly happens and is the ideal place.
Total: €1159.54
The 903 if using air cooling seeing how those fish tank cases such as the XR usually have bad airflow as in no front mesh panel with front intake fans. If wanting a 150mm psu for that Lian Li case then look at the Corsair RMe or MSI GL.
Their site says a 160mm fits. Looks like connections may be snug with that though the way the psu mounts sideways in the front.
Honestly I would wait a bit for the new GPUs that are about to come out in a couple of months. You could then either get a better graphic card for the money or get the same gpu cheaper.
Buying new right now is a bit of a lose/lose situation whatever you buy.
Fixed
PCPartPicker Part List: https://nl.pcpartpicker.com/list/WdY6rM
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (€185.00 @ Amazon Netherlands)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-7000 CL32 Memory (€109.00 @ Megekko)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€115.48 @ Azerty)
Video Card: Inno3D Twin X2 GeForce RTX 4070 SUPER 12 GB Video Card (€629.00 @ Megekko)
Power Supply: be quiet! Pure Power 12 750 W 80+ Gold Certified ATX Power Supply (€91.90 @ Amazon Netherlands)
Total: €1415.23
Generated by PCPartPicker 2024-12-24 14:28 CET+0100
You can run the RAM at a lower MT rating, it's just better binned than the kit you chose, and cheaper too.
No point buying a budget CPU then adding 25 euros for a cooler, just get the next one up and use the boxed cooler.
It's also likely a good idea to wait for RTX 50xx, since current gen GPUs are long in the tooth but not discounted.
If you can bump the budget a 9800X3D is a great improvement if you're concerned about CPU limits.
Likely a good idea to get an ATX 3/3.1 PSU too.
The 4070s is notably faster and more efficient than the 7700XT and allows for RT and access to DLSS/DLAA.
1 TB QLC single drive system is simply too small and slow for 2025.
iGPU of the 7600 is a good backup to have if your GPU fails at any point too, unlike the 7500F.
Total: €1159.54
Go with it
I think this is it, I added the extra case fan and went with the other PSU as per your recommendation (Thank you btw).
Power Supply: be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€114.60 @ Azerty)
Case Fan: ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan (€7.99 @ Amazon Netherlands)
Total: €1187.23
Generated by PCPartPicker 2024-12-24 16:00 CET+0100
Someone fit the 2024 rm850x 160mm in it and it looks fine so I guess it differs between models.
I didn't think about that. I'm kinda in the need of a PC tho. Would buying and assembling the parts right now and waiting next month for the release of the new GPUs be a smart idea?
Idk what binning is and when I looked it up I still don't rly get it, it looks wayyyyy too advanced for me, can you explain. The one I picked is 90 cents more expensive than your pick.
wait actually?
Yea, I'll put that in, thanks.
I'm not rly considering RT. I went with the 7800XT.
I feel like if I need more I can just add another SSD later on. The main purpose is to play games on it and some light coding as well, QLC should do the job well enough for the priceI think.
wait actually?
I wouldn’t go with a QLC drive as primary (OS drive). And only 1TB. At least 2TB if it’s QLC and never fill it past 50%.
I think this will wear out relatively quickly, of course depending also on how often installations will happen but as an OS drive alone the write entries will be a lot and constant.
It’s about longevity not space necessarily.
