Fix RX580 with hardware programmer
XzReaN
5 (0.01/day)
Hello,
I am using Rx 580 Graphics card. One day, while changing the cards, 1 card did not work again. I used this method. It didn't happen again. The fans do not spin, but the computer turns on, there is no image, the graphics card processor does not heat up. What's the problem?
I don't know English, I use translation.
If you want to flash with a hardware programmer you will still need the proper bios for your card.
For others to help you find the correct bios to flash you will need to tell us the exact model and ideally provide us with a clear picture of the memory chips.
Xfx Rx 580 8 gb
samsung vram
vram photo
You can attempt start by trying these:
Given the clock rates there are the gaming bios.
I tried all bios. no image. The processor does not heat up.
GPU riser is working. It displays with another graphics card.
It just could be bad, the next step would be to re paste it and put the cooler back on, then boot the system with a good GPU and that one in a secondary slot. Then we can see if its even detected by the system.
I am using the same graphics card. When we plug both in at the same time, there is still no image. the computer turns on. I tried it via remote connection but it doesn't see the gpu. Only working GPU appears. 2. no gpu
During remote connection events, there is a small screen and the flash does not work. I tried with ch341a and it still doesn't work.
I think the fuse is broken on the faulty card. Likely a short circuit.
