Flash another RTX 4060 vBIOS to get zero rpm fan support
uel
6 (0.43/day)
Hello everyone,
Is there a vBIOS that I can flash to my 4060, that supports zero rpm fan setting?
Graphics Card: ZOTAC RTX 4060 SOLO
Current vBIOS: 95.07.36.00.71
44,274 (6.80/day)
Go on vga bios collection and look.
Ruru
S.T.A.R.S.
13,780 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Can't you just make a custom fan profile?
44,274 (6.80/day)
This makes the most sense, also not all cards are capable of it depending on the fan motors, and thermal characteristics, perhaps the user should just get a chunky heatsink or a waterblock.
303 (0.10/day)
System Name nVAMDia
Processor Ryzen 7900 at 145Watts PPT.
Motherboard MSI MAG x670 Tomahawk Wifi
Cooling AIO240 for CPU, Wraith Prism's Fan for RAM but suspended above it without touching anything in case.
Memory 32GB dual channel Gskill DDR6000CL30
Video Card(s) Zotac 5070 gaming solid oc + Msi Ventus 2x Rtx 4070
Storage Samsung Evo 970
Display(s) Old 1080p 60FPS Samsung
Case Normal atx
Audio Device(s) Dunno
Power Supply 1200Watts (8x 8-pin)
Mouse wireless & quiet
Keyboard wireless & quiet
VR HMD No
Benchmark Scores The best GPU in the world is the brain. 100!
The best way to not hear the fan noise is to use headphones in gaming.
I wear headphones and listen to battle in planetside 2. When 150 players in battle, I dont even hear the fan at 65%.
There are like 30 main battletanks going pew pew and 20 snipers trying to shoot me constructing a tower and theres a bus with 2 turrets trying to shoot the aircrafts. Hear no fan at all.
But when playing furmark, its totally unacceptable. The buzz sound is irritating even more than fan sound.
uel
6 (0.43/day)
sorry that is not what i am asking. i want 0 rpm when idle.
for people looking for an answer:
I just flashed the bios of an Colorful RTX 4060 8 GB BIOS and it instantly went to 0 rpm after flashing, lol.
Why is this even locked away in firmware? :kookoo:
Download Fan Control - A highly focused fan controlling software for Windows
This will allow you to control the fans including the zero RPM.
I tried setting fan speed via FanControl or MSI Afterburner but < 30% fan speed it just does nothing. ¯\_(ツ)_/¯
724 (0.14/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper
Keyboard Razer Huntsman Elite
FanControl should allow you to control the fans including the zero RPM.
When you calibrate the fans, it should have a point where they stop spinning.
My case fans stop at about 28%.
520 (0.34/day)
Processor AMD 7600x
Motherboard Asrock x670e Steel Legend
Cooling Silver Arrow Extreme IBe Rev B with 2x 120 Gentle Typhoons
Memory 4x16Gb Patriot Viper Non RGB @ 6000 30-36-36-36-40
Video Card(s) XFX 6950XT MERC 319
Storage 2x Crucial P5 Plus 1Tb NVME
Display(s) 3x Dell Ultrasharp U2414h
Case Coolermaster Stacker 832
Power Supply Thermaltake Toughpower PF3 850 watt
Mouse Logitech G502 (OG)
Keyboard Logitech G512
Because
Because depending on design/implementaion of the cooler especially for things like memory and VRM having 0 airflow will just lead to premature failure of the card
uel
6 (0.43/day)
Because
could be true. could also be the typical marketing fluff to up sell you another card.
44,274 (6.80/day)
Go try the files then.
You can always get a hexadecimal reader/converter and look
44,274 (6.80/day)
A good bet might also be to buy an fan-header extension and connect the GPU fan to your motherboard and control it from there.
And then it will be based upon the mobo not the gpu and you risk it not ramping up when need be, just get a rheostat and manually control it.
uel
6 (0.43/day)
you can couple it with any sensor via software like fancontrol
