- Mar 27, 2009
- 134 (0.02/day)
- Pittsfield, Massachusetts
System Name | Gaming rig |
Processor | Intel i7 7700K at 4.4GHZ |
Motherboard | Asrock Z270M-ITX/AC |
Cooling | Cryorig H7 |
Memory | Crappy 16GB memory |
Video Card(s) | Zotac 3060ti undervolted at .850mv |
Storage | WD m2 Sata SSD + WD 10TB HD |
Display(s) | 27 inch LG 1440p 144hz + 27 inch Lenovo Thinkvision 1440p 60hz |
Case | Thermaltake Versa H18 |
Audio Device(s) | Klipsch Promedia 2.1 speakers |
Power Supply | EVGA 600W |
Mouse | Coolermaster MM711 |
Keyboard | Steelseries Merc Stealth |
so summer has hit massachusetts and now on prime95 my phenom 2 720 is hitting 62 celsius. This is on stock voltage at 3.3 ghz and yes i have stock heatsink for now. So i moved the clock back to 2.8 which is stock and the temps are the same. So i tried to lower the voltage below default in the bios but it seems it wont let me. The option shows a digit 0 - 25 where each integer is a stepping of .024v or .0024 i cant remember. Anyways i cant go negative. I can lower the voltage in overdrive and ive managed to get 3.1 ghz at 1.3v stable. The temps are down to 58 with that. Can anyone help me? is there any way to lower the voltage in BIOS?
