Fractal Design Intros Meshify 3 PC Case, Momentum Fan Series, and Adjust Pro Hub
Nomad76
1,397 (3.64/day)
Announcing the Meshify 3 series of performance PC cases, the powerful Momentum series of fans, and the Adjust Pro Hub for connecting devices to our new online configurator.
Introducing Meshify 3—a performance PC case series combining top-tier cooling with fluid, aerodynamic design. An evolution of our classic series, Meshify 3 includes several performance-boosting engineering upgrades and a fresh new look. With ample ventilation, a rockface-inspired mesh front, and the inclusion of three powerful Momentum 140 mm fans—Meshify 3 series is built for cooler performance. The standard-size version can also house up to a 280 mm top radiator and 360 mm front radiator for further cooling, with space for a graphics card up to 349 mm in length.
[Editor's note: Our in-depth review of Fractal Design Meshify 3 Ambience Pro RGB is now live]
Meshify 3 XL offers a highly expansive interior and multi-radiator support, with space for up to a 420 mm top radiator and up to 360 mm front and side radiators, for advanced cooling and custom loops. It can also house a graphics card up to 512 mm in length, offering generous compatibility with the largest components.
The Ambience Pro RGB versions enhance the experience further with ARGB Gen 2 integrated atmospheric lighting and fans, which are easily controlled through our intuitive web-based software accessed via the included Adjust Pro Hub.
Introducing Momentum
Momentum is a high-performance fan series that fuses premium materials with performance engineering to minimize noise while maximizing cooling efficiency.
It combines a swept blade design, vibration-reducing rubber bushings, and true fluid dynamic bearing technology to ensure quieter operation. To further improve efficiency, Momentum features blades constructed from Liquid Crystal Polymer (LCP), reducing the required distance between the rotor and frame for smooth operation at high rotational speeds.
Introducing Adjust Pro Hub
Ambience Pro RGB versions of Meshify 3 and Meshify 3 XL include a pre-routed Adjust Pro Hub, a device that enables control of components through Adjust Pro—our new online configuration tool.
Adjust Pro is a download-free, web-based software solution accessed by visiting the Adjust Pro web address in a chromium-based desktop web browser.
It allows users to customize the lighting of their ARGB Gen 2 components, such as the included Momentum RGB fans and ambient case lighting, as well as set speed curves for Momentum and other PWM fans, without needing to download or run processor-consuming software.
Users can choose between curated Fractal lighting themes featuring ARGB Gen 2 animations or decide to create their own look, with lighting and fan speed settings stored locally on the Hub.
Micro USB on a new product in 2025?
I'm more interested in the chair and desk. They look nice.
Edit: Just checked the chair, they are asking for 600$ for a piece of plastic. Maybe their margins are tight but nonetheless no thank you that's too much for a chair.
