Fraps to Youtube help
lyndonguitar
I play games
1,878 (0.34/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
I edited some of my Battlefield 3 fraps recordings and edited them using Sony Vegas(I'm still a newbie), created a montage and uploaded them to youtube in 720p.
I have done two videos now so far. But the thing is. the size of the rendered file is still big. first one is about 2.5 mins and its 700 MB, the second one is 3.5 mins and its about 1 GB.
my upload speed is too slow and I was able to upload it for like 4 Hours. :banghead:
anyway I could reduce it to at least below 500 MB without losing any detail? or losing just a very small amount, still capable of 720p.
Any fraps -> youtube uploaders here? What program/presets do you use? :confused:
oh and here is my video if you would like to watch it.
http://www.youtube.com/watch?v=rSgk8TtEhW8
WinAVI will compress the video files for you after you have compiled them in Sony vegas. I usta do counter strike videos and I used it with not much quality loss. It would take a 400MB file down to around 10-20MB
but still 720p-ish??? if so, wow thats a life saver
You appear to be using uncompressed video, try rendering it with lower bit rate/ higher amount of allowed reference frames (although i'm not sure of how Sony Vegas renders things so that may be easier said then done)
or alternatively run the file through handbrake on the high profile preset if you want a high quality file with a low filesize
thanks for the tip guys, i used WinAVI and selected AVI 720p HD and converted the files.
3.90 GB became 49.8 MB with little to no loss of quality! What a relief
