A friend of mine recently got an RTX 3060 Ti and for some reason sometimes his games (Wild assault, Elder scrolls online, genshin impact, fortnite) makes his monitor fully shut down (Since he uses it's speakers these also are turned off), altho he says the monitor's light blinks when it happens. However it also happens when doing light tasks like watching a stream, drawing, etc. His PC tower, however, is still turned on (No restart, no shutdown) when this happens
He tried using his 32" LG TV (NON OLED) and the same issue happens. He even tried lowering the resolution from 1080p to 1360x768 but nothing.
His previous GPU, ASUS 1050 Ti 4GB OC, NEVER did this tho.
His actual specs are:
-ASUS PRIME a320m-k (2017, the oldest stuff)
-GIGABYTE AORUS RTX 3060 Ti 8GB
-32GB DDR4 RAM Micron
-2 SSDs
-Cougar XTC argb 650 650 W
-PHILIPS 24E1N1100A
-W11 latest version
-Nvidia drivers updated
He used a new HDMI 2.0 cable too that's not the one that might've come with the GPU
If it kinda helps, he says that playing ATLYSS or COMMAND & CONQUER REMASTERED DOESN'T causes these issues (But again, now it happens when doing lighter things)
I suspect a few things for now:
-He shown me his new bought HDMI cable, 2.0 4K supported "with ethernet" and 1.8 meters, and the cable might not be good enough?. Should he get something like a UGREEN?
-CPU bottlenecking the GPU causes the screen to power off because it can't power powerful games or something?
-PSU is weak and doesn't powers the GPU properly?
-The monitor and TV are just weak?
Thanks in advance
-2 SSDs
-PHILIPS 24E1N1100A
-W11 latest version
Thanks in advance
