Full-range speakers
231 (0.06/day)
System Name hazazs
Processor Intel Core i7-6700K @4.0GHz
Motherboard MSI B250 GAMING M3
Cooling be quiet! Shadow Rock Slim / 2 * be quiet! Shadow Wings 140mm / 3 * be quiet! Shadow Wings 120mm
Memory 2 * 8GB Corsair Vengeance LPX DDR4 @2133MHz CL13 Red
Video Card(s) MSI GTX 980 Gaming 4G
Storage Samsung 970 EVO Plus 1TB / Kingston DataTraveler SE9 G2 8GB
Display(s) Dell P2219H / SONY KDL-43W755C
Case Cooler Master Silencio 652S
Audio Device(s) Creative Inspire P580 / Sennheiser PC 320
Power Supply Cooler Master V550 Semi-Modular
Mouse Logitech G300S
Keyboard Logitech Ultra-Flat
Software Microsoft Windows 10 Professional x64
Hi all,
I have an ALC1220 integrated audio codec. In Realtek HD Audio Manager there is a feature called full-range speakers:
Should I enable the Front left and right option with a Creative Inspire P580 (I use it as 2.1) which frequency response is (in paper) 40-20000Hz?
Thanks,
hazazs
Hi all,
Thanks,
hazazs
How did you connect the speakers? If you used Stereo, the set as full range.
If you set the subwoofer in settings then don't set as full range.
Yes, enable it. I'm using creative t20's and it outputs the whole signal instead of cutting off bass.
I used it as Stereo (according to the Windows/Realtek setting), but the subwoofer works with the two satellites as well.
