Fully featured Firefox with reasonable memory usage is possible?
grazzhoppa
219 (0.03/day)
Processor Core 2 Duo E6750 @ 3.3GHz
Motherboard Abit IP35 Pro
Cooling Scythe Ninja, two 600RPM 12CM fans
Memory 4GB DDR2 @ 832MHz, 4-4-4-12 2T
Video Card(s) NVIDIA 8800GT @ 715/980 passively cooled
Storage 1TB WD10EARS, 500GB WD5000AAKS, 250GB HM250JI
Display(s) Samsung 204b LCD
Case Ultra Wizard
Audio Device(s) Onboard Realtek ALC888
Power Supply Seasonic S12-II 380 watt
Software Windows 7 Pro. (x64)
Firefox consumes 450 MB of memory after 5 days of running with the extensions I have installed. I would like lower memory usage, but it is possible with Firefox and the extensions I have installed?
Click the image for a large, readable picture (400KB)
I don't want to uninstall the extensions because each extension other than FoxyTunes and StatusBarEx are essential to me.
Firefox 3 Beta 3 helps ALOT
Firefox has a memory leak.... it does this if you leave it running ;)
You can set the amount of memory, which the browser can use by going to about:config and changing the setting. I don't remember the exact setting you had to change but i think it was "browser.cache.memory.capacity". Just lower this value and see if less memory is used.
If it didn't work then search for a firefox optimiser document on the net and it should contain this kind of information on how to make firefox faster and use less memory. This worked for me but it was a long time ago so i don't remember the exact things i changed. Well, what i did was I went and found some information on optimising firefox and after reading through it and changing whatever necessary my firefox used much less memory and was a lot faster in starting and loading large sessions.
you can also use the firefox ultimate optimizer... there's a thread here on tpu about it... lemme see if i can dig it up.
edit: found it
i think it also speeds up firefox a bit, but maybe that's just my brain playing tricks on me(it likes to shift gears...)
