G.SKILL Ripjaws Z Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000)
1,644 (0.27/day)
System Name Black Killing Machine
Processor Delidded NO IHS mount Intel i7-4770k
Motherboard Gigabyte Z87X-OC
Cooling Swiftech DIR655 pump, Watercool HEATKILLER® GPU-X³ 79X0 Ni-Bl gpu, DT SNIPER CPU block, UT60 420 RAD
Memory Gskill Trident 2400mhz CL9 Samsung IC9
Video Card(s) SAPPHIRE HD7950 OC 950mhz Edition, VaporX HD7950
Storage 2xM4 Crucial 64GB RAID 0, 1 OCZ AGILILITY 3 60GB, WDCB 500GB x2RAID0, WD Green, Hitachi 1TB
Display(s) Samsung SyncMaster 226BW and 24" 120hz BenQ gamer
Case SilverStone Raven rv-02
Audio Device(s) Audio Technica ATH-AD900 headphones, Topping D2 DAC/Headphone AMP
Power Supply Seasonic Platinum 860
Software Windows 7 Pro 64bit
Benchmark Scores http://hwbot.org/user/sonda5/ Delidding is magic. http://valid.canardpc.com/2878462
Just got the ram yesterday.
My first test was a low voltage test.
Set timings at 1T-10-11-10-28 with voltage at 1.5v@2141mhz and ran perfectly stable for over 4 hours with memtest86+ v4.20.
BiOS settings for test.
All tests were done with stock i5-2500k heat sink.
2,350 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
I've been running mine {4gb x 2} at 1600, 8-8-8-24 1T @ 1.5v.
2600K @ 4GHz.
I had them at 2133 @ 1.55v : no need for "xmp" 1.65v.
These kits seem very friendly to a wide variety of settings.
1,644 (0.27/day)
I have yet to see how they perform with the cpu over clocked. Going to install OS soon and get everything dialed in.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
keep us informed pls
3,145 (0.64/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
Tighten your timings and feed it MOAR voltage
1,644 (0.27/day)
I'd like to keep voltage as low as possible. I don't plan on going higher than 1.65v. Also If possible I'm going to see if these sticks will do 2400mhz with timings around 11-12-11-30, 6-6-6-24 at 1600mhz, 8-8-8-24 at 1866mhz all at 1.5v.
DDR3 is very cheap these days and I spent quite a bit of money for this set because I wanted a set of DDR3 that had more room for over clocking CPU and I also a wanted a set that would do well with my planned i5-3750k upgrade later on next year. I feel confident this set of ram will go a long ways for over clocking my system.
1,644 (0.27/day)
This ram has 2 XMP settings. XMP profiles work fine with MSI Z68 GD65 G3.
XMP Profile stable with BIOS settings.
1,644 (0.27/day)
MaxMem benchmark with the xmp profile enabled.
259 (0.05/day)
Poznan, Poland
I wish to see this kit on max clocks but it's probably impossible on SB. I doubt that you make it stable much above 2200 so at this point is only way to lower timings.
I would check something like 8-11-8 or 9-10-9 1.6-1.65V.
1,644 (0.27/day)
Stable at XMP profile 2133mhz with 1.61v. Very good performance. I think it will do at least 2300mhz.
