games cause my computer to restart , help me solve the problem
  • Thread starter Thread starter wolf2009
  • Start date Start date
W
wolf2009
My system :
ASUS A7N8X Mobo nforce2 chipset, 420 W PSU 18 A on 12 V rail , AMD AthlonXP 2800+ Barton , 1 GB DDR333 RAM , 7600 GT AGP , Creative X-fi Xtreme Audio , Windows XP.
Some games like Splinter Cell, Driver 3 , San Andreas cause my computer to restart .
I have the latest drivers for everything .
When i report the error to microsoft i get this response :
Problem caused by Device Driver
You received this message because a device driver installed on your computer caused the Windows operating system to stop unexpectedly. This type of error is referred to as a "stop error." A stop error requires you to restart your computer.
I dont know which driver is causing this .
EDIT : This is what i got on BSOD ,
DRIVER_IRQL_NOT_LESS_OR_EQUAL
p17xfi.sys - Address f69ed0c7 base at f69bd000
that file p17xfi.sys , is that related to my creative x-fi soundcard drivers ?
i have the latest drivers for that card .
EDIT : I removed the X-fi Sound Card and its drivers , First uninstalled with revouninstaller , then cleaned in safe mode with driver sweeper and driver cleaner .
And now all the games work . So i guess it was the card causing all the problems . SO what should i do now , i had the latest drivers for that card .
UPDATE : I reinstalled the drivers and put the soundcard , and again the same problem .
I also did memtest and got errors . So is it the RAM or the soundcard drivers ?
If it shuts off completely then thats a psu problem.
might be an IO or allocation error causing it because of the drivers used by your mobo try reinstalling those.
Ah, yes! With an older system like his this is very possible. I love it that IRQ settings are a thing of the past.
i know right IRQ error whats that? but i got them on my old nforce 2 rig
turn off automatic restart in windows on crash,
rightclick on my computer, properties, advanced tab, startup and recovery, uncheck box "Automatically restart"
this wont fix it, but it should give you a BSOD that will give you information on whats going wrong.
your computer sounds like it's tired of playing games.
on a helpful note.... pull your x-fi out and remove all the drivers.
yay, i am glad you figured that out, if it makes you feel better i have one of those x-fi extreme audio cards aswell, mine is a pci express one, i paid like around 50 bux for it, and i wish i didnt, its just another software card, granted it has some cool features for a software card, but i didnt really need it, mine hasnt been makeing anything crash, but then again the newest thing i have been running lately is ragnarok online, maybe i can trade it for something, good to know its gonna give me problems :?
p17 is an X-FI driver.San Andreas used to crash for me when my overclock/memory timings had been pushed too far.
I used to get that error when gaming, if it comes back change your ram, worked for me. 1 year later, no BSOD. I read up on it ALOT and nearly everyone says its a RAM issue. Don't be suprised if it comes back.
hmm i think i need to try this to mybe makes my oc more stable
I had this same problem with Manhunt.. just stopped playing it after it happened xD
i have an idea that will solve all your probs ill trade you my sound card for yours....
