Games stutter and sort of lag, but fps counter says fps is steady at whatever I set it to.
MartinB2002
1 (0.00/day)
I'm a bit of a noob in terms of pc gaming and run into this weird issue. I use a Lenovo Laptop that is defenitely capable of running games steadily. It has done it in the passed, so I know for sure. It could run GTA V, Far Cry New Dawn, Rocket League among other games without any performance issues. For some reason, since a couple weeks I think, it has started to run games very poorly. I tried deleting and installing drivers, checking for updates but nothing seems to help. I turned on the performance stats overlay in the NVidia GeForce Experience app and it says the fps is steady at whatever I set it to in game. Like in FIFA 22 I set it to 60 and the fps overlay says its running 74. But I still feel like I get fps lag spikes and the game just stutters in general. I am completely lost here.
I've got a Lenove IdeaPad L340 Gaming with a GTX 1650 and 16gb of ram.
23,890 (6.16/day)
Please provide your system specs, or the laptop model.
The first thing that comes to mind is throttling, age = dust build up and throttling may become a performance hit you can feel over time. That is just a general comment though.
Specifically on your example (very little info is provided so that's what I work with now) of FIFA22, if you set your ingame FPS to 60 and the overlay shows you run 74, the stutter may happen because FPS is not synced to refresh rate. Use Vsync (Adaptive probably best) to see if that fixes your problem there. And if it does, you have your answer - sync refresh rate and FPS, or limit your FPS to refresh rate (just under or over can work magic as well, and work differently per game).
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Check the link in my sig, the top one.
Theres a lot in there, but it's absolutely relevant to helping diagnose your situation here and the types of info that will help us
What's changed with the laptop? Vsync? Gsync?
Does it happen when offline?
Does it happen when on battery?
Does it happen on mains, with the battery removed?
