- May 30, 2007
- 9,019 (1.37/day)
System Name | Black Panther |
Processor | i9 9900k |
Motherboard | Gigabyte Z390 AORUS PRO Wifi 1.0 |
Cooling | NZXT Kraken X72 360mm |
Memory | 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz |
Video Card(s) | Palit RTX2080 Ti Dual 11GB DDR6 |
Storage | Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm |
Display(s) | 32'' Gigabyte G32QC 2560x1440 165Hz |
Case | NZXT H710i Black |
Audio Device(s) | Razer Electra V2 & Z5500 Speakers |
Power Supply | Seasonic Focus GX-850 Gold 80+ |
Mouse | Some Corsair lost the box forgot the model |
Keyboard | Motospeed |
Software | Windows 10 |
I've spent the last couple of afternoons researching, reading threads here and looking online.
Currently I'm using a USB Toshiba optical wired 800 dpi.
It isn't bad but I'm sure it isn't gaming standard. I have never owned a 'gaming' mouse yet
and though this toshiba works well as regards the 2 buttons and wheels, it somewhat 'sticks' no matter how much I clean the surface and its pads, and it is somewhat too small for my hand and definitely waaay too light, it's so light I wouldn't know if it's in my hand or not!
I've seen a lot of posts in favour of the Logitech G5, however it's a bit 'old' now? Surely something better has replaced it? Is the G9 a good improvement over the G5?
About what I look for in a mouse -
- it must be slightly larger
- it must be heavier
- colour must be preferably black and blue / neutral grey or black and if it has designs/lights they must be blue
- it must be good for gaming and not stick and jump!
- it's pointer must move a lot compared to the movement of the physical mouse. I keep my mouse on the part of the desk on which my keyboard is, and there's like not much space to move it around. The way things are I end up 'kicking' the keyboard with my thumb while gaming (distracting!). I got only like 19cm horizontal space <---> where to move the mouse and that's 7.5 inches.
- wired. They're better for gaming and I don't want to deal with battery panic...
I'd prefer to purchase locally though the choice is limited:
G5 from Scan Malta
G5 from MTMalta I wonder the price difference from Scan? MTMalta updated this mouse 2005 I heard there was a new release of G5 in 2007? How do I recognise off-hand which is which?
Razer Copperhead from Scan Malta
Razer Deathadder from mmd-trading Malta
GM3200 from mmd-trading malta
Razer Lachesis from mmd-trading malta
Or from Overclockers UK.....
(I'm really liking the lachesis it's 4000dpi but I read that it's driver is crappy and gives a lot of trouble?) Is this true and common? Anyone owns a lachesis? What are your experiences on XP?
Logitech G9 from overclockers.co.uk
What do you think would be the best in my case? Budget's no problem for once... a mouse is never that expensive
G5 from Scan Malta
