Geforce 3070 Rtx - 30% GPU usage in idle? (Video encode)
37 (0.02/day)
Processor I7 10700K
Motherboard ASUS Z490-F Gaming Rog Strix
Cooling Air
Memory 2x 16GB HyperX DDR4
Video Card(s) Gainward Geforce RTX 4070 Ti
Storage 2x Fore MP600 Gen 4 NVME
Display(s) 32 P Wide
Power Supply EA750G Pro 750 W
Hello,
just to have a comparison with same configuration, do you have 30% of GPU usage in idle in Windows 10 20H2? It's very strange for me because it seems not be usual.
Thank you !
474 (0.29/day)
System Name Dusty
Processor 5900x
Motherboard MSI B550 Tomahawk
Memory Corsair Vengence LPX 32GB
Video Card(s) MSI RTX 3070 Gaming X
Storage yes
Case Fractal Design Define R6
Power Supply EVGA SuperNOVA 750w
VR HMD Oculus CV1
Shadowplay? Background apps? with shadowplay on mine goes between 10-30% usage on Video Encode. Since it is after all, constantly recording.
Deleted member 205776
No. I have GeForce Experience installed, with instant replay off. Idling, browsing and watching YouTube only puts my 3070 at 0-5% loads. Windows 10 20H2 build 19042.804. Driver ver 461.40.
37 (0.02/day)
Processor I7 10700K
Cooling Air
Of I disabled shadow play it's the same it's why is very strange. With my old configuration with gtx 980, it was only 10% of gpu usage for shadow play.
It seems use more gpu for encoding during idle than when I play a game
3,871 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Hello,
Thank you !
You clearly have something using the gpu, ie. hw accel, hardware acceleration. Use afterburner and click on the "i" button, scroll down to active 3D process. Whatever that is there that you don't explicitly want to use your gpu on the desktop, copy pasta the app.exe and paste into Rivatuner. Open Rivatuner click add, paste that exe and set application detection level to none, then close rivetuner and it'll auto restart and disable said app upon its restart.
23,872 (6.16/day)
You need to shut down your miner :roll:
37 (0.02/day)
Processor I7 10700K
Cooling Air
Hi when i checking in the i of after burning nothing seems use the 3d processor
Chemin : C:\Program Files (x86)\RivaTuner Statistics Server
Version : v7.2.3
Client(s) actif(s) : Module de monitoring d'images par seconde
: Module de sur-impréssion d'écran
Processeur 3D actif : Non détecté => (not detected)
Today i disable the shadow play and now it's 0% as expected. When i active it again 30 % is it a normal use for shadow play? Thank you
When i looking a video on youtube, i use 3D Gpu... wow
3,871 (0.74/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Yesterday you wrote that it shadowplay didn't affect anything and now you write that it does.
37 (0.02/day)
Processor I7 10700K
Cooling Air
Yes exactly yesterday disable shadow play did not affect the GPU usage, it's why i said "today" :) and why it's strange for me.
Roadkillcafe
1 (0.00/day)
I forgot I had shadowplay enabled. Quickest "well duh" reading your comment while trying to figure out my encoding not being at 0 while idle.
15 (0.02/day)
System Name Eif PC
Processor Ryzen 9 5900x / Ryzen 5 5600 / ryzen 3 3100
Motherboard ASROCK B550 EXTREME4 / TUF GAMING B450M-PLUS II / B450 M aouros elite
Cooling Cooler MasterLiquid Lite 120 / COOLERMASTER MASTERLIQUID ML240L V2 ARGB
Memory 32 gb gkill 3600 cl 16 / 32 gb 3200 cl 14
Video Card(s) GIGABYTE GEFORCE RTX 3070 GAMING OC / Zotac GTX 1660 super 2200 mghz /
Storage 120 gb M2 / 1 TB 7200 / 2 TB 5400 / 500 GB SSD
Display(s) GIGABYTE G24F 2- 24" - 165HZ - IPS / GIGABYTE G24F 2- 24" - 165HZ - IPS / GIGABYTE G24F 2- 24" - 165
Case NZXT 510
Power Supply GIGABYTE P850GM - 80 PLUS GOLD / GIGABYTE P850GM - 80 PLUS GOLD
Mouse LOGITECH G203 Prodigy / LOGITECH G502 HERO
Keyboard REDRAGON K585 DITI / RAZER CYNOSA LITE - RGB-ESPAÑOL
Software win 10 / win 11
all by default with two monitors at the same time, while one plays youtube
