GeForce GTX 580 Cooling Solution Detailed to Public
47,655 (7.43/day)
NVIDIA is just a couple of days away from releasing the GeForce GTX 580, the company's trump card which came literally out of nowhere, compared to AMD's Northern Island GPUs, which were talked about for months. At the PDXLAN 16.5 event, NVIDIA showed off some slides that are most relevant to gamers, notably the thermal and acoustic characteristics of the reference design thermal solution. The latest thermal solution does look a lot more compact compared to that of the GTX 480, especially the lack of that hot-plate and heat pipes sticking out is notable.
The new cooling solution relies on vapor-chamber technology to convey heat to the aluminum fins, instead of heat pipes. The fan features a more refined adaptive fan profile. Combined with a more power optimized GPU, the new thermal solution is said to be more efficient and quiet compared to even that of the GeForce GTX 285.
251 (0.05/day)
They found they way to prevent reactor meltdown. Good.
Even so, nV's best seller after 460 will probably the 460 SE (the 6/8 clusters enabled GF104).
1,015 (0.18/day)
Processor Intel Core i5 8400
Cooling Silverstone AR05
Display(s) Dell U2415
Case Silverstone RVZ02B
Keyboard Ducky One Red Switch
Software Windows 10 Pro 1909
still not convinced on those tiny fans, they look like they need to spin 3000 rpm to have any realistic airflow
64 (0.01/day)
System Name B501-YukiHime
Processor AMD Ryzen 5 2600 (no OC)
Motherboard MSI B450M Bazooka Plus
Cooling Deepcool Gammaxx L240 V2 AIO, Deepcool RF120M 3-Pack
Memory 32GB (2x 16GB) Kingston HyperX Fury DDR4 3200mhz
Video Card(s) MSI Radeon RX 5700 Mech OC (Stock BIOS)
Storage 990 PRO 1TB, 990 EVO 2TB, 870 EVO 1TB, BX500 960GB, 4TB Seagate HDD, 2TB Seagate HDD
Display(s) Asus VX279H ; NEC MultiSync EA234WMi
Case Fractal Design Node 804
Audio Device(s) Logitech Z213; SteelSeries Arctis 1 Wireless
Power Supply MSI MAG A750GL PCIE5 750W 80+ Gold
Mouse Logitech G604
Keyboard Logitech G710+ (Cherry MX Brown)
Software Windows 10 Pro 64bit v21H1
They must say "EVEN BETTER THAN GTX 480" rather than 285...:nutkick:
5,614 (0.99/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
I thought the presentation and the demo were amazing stuff, and I can't wait to see the product in actuality rather than on slides and on paper!
1,165 (0.20/day)
I live in Norway
Processor 9800x3D| 5800x | 4800H | Rog ally
Motherboard Gb x870 Aorus Elite ice | Asrack x470d4u | Asus Tuf A15
Video Card(s) RTX 4080 |Quadro P5000 | RTX2060M
Storage Many drives
Display(s) AW3423dwf.
Case Jonsbo D41
Mouse g502x Lightspeed
Keyboard G913 tkl
Software win11, proxmox
nvidia should drop anything lower than 440/540,
Fusion, and sandy bridge is comming, and it will hit nvidia hard.
Unless nvidia can keep themself real and really good in the server market, and will provide good technologies.
But they will become smaller in terms of volume, but maybe not profits.
Nvidia's move have been smart, but i dont know if its enough.
fusion is really fast, faster than you might expect, and i've heard sandy is also quite impressing, to be intel we're talking about.
Good gtx580 comes, cause 6970 and 6990 will be quite powerfull, and 580 will bring prices down hopefully.
my 5850 still cost more now than it did release day, and the 2 following months after release.
18,452 (2.47/day)
1,165 (0.20/day)
I live in Norway
Storage Many drives
Case Jonsbo D41
Keyboard G913 tkl
5,048 (0.92/day)
València la Vella
I never believed 'vapor-tech'.... The slide shows liquid 'dripping' down to the core, when in a real "case" it would be upside down... Is there really a liquid supposed to be travelling inside the block? Maybe I am just thick this early in the marning! :)
9,899 (1.66/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Yeah there is a liquid, it evaporates and travels as the speed of sound in a vacuum ( so much faster than conduction :laugh:) and takes the heat to the other side of the vapour chamber or pipe.
And since lots of fins are there the vapour cools down back into a liquid and wicks back to the start where it happens again.
Necrofire
585 (0.09/day)
System Name Chuck
Processor Core i5-2500k @ 4.5Ghz
Motherboard msi P67A-C43
Cooling hyper 212, 2 120mm fans
Memory 8GB DDR3 1600MHz
Video Card(s) XFX 6870
Storage 60GB sata3 sandforce ssd, 1TB samsung hdd
Display(s) Yamakazi Catleap
Case Possibly Antec, not sure
Power Supply Rosewill 600W
It's probably textured on the inside, so that the inside surface acts like a wick, just like in heatpipes.
1,015 (0.18/day)
in theory the fluid will travel back near the gpu by capillary action. How well that works in practice is another story...
W
wahdangun
hmm isn't vapor chamber was own by ati/shapire ???
btw i hope its not just fully enabled GTX 480,
i can't wait to see the benches but shame nvdia won't provide TPU a card,
Athlon2K15
HyperVtX™
7,909 (1.17/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
You must not understand that the GTX285 was nvidia's quietest card as far as fan noise goes, So for them to make it better than a 285 is impressive.:nutkick:
9,899 (1.66/day)
Essex, England
System Name My pc
No those two don't own it.
It's quite an old discovery the ole vapour cooling.
@Necrofire here's the patent to a particular type of flat heatpipe
http://www.freepatentsonline.com/6679318.html
get to see a cut away diagram.
64 (0.01/day)
Mouse Logitech G604
Oh, Is that so? I'm referring the THERMAL OUTPUT of the upcoming card... If they said it, then, they must make it sure that it is true, or else, another epic fail... or not...
1,180 (0.19/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
3,316 (0.52/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + P12 Max 3300 RPM
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G304
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
Clearly, you were reffering to the slide.. when it clearly stated 'Accoustics' in the corner. Try and read first before commenting.
47,655 (7.43/day)
GTX285 cooling solution is already better than GTX480.
5,250 (0.84/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
at last they think about them suck reference cooling
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
This is looking very impressive. TheGTX580 may very well be the first Nvidia GPU to hit 1GHz on Air :D
2,668 (0.42/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
vapor chamber technology nice
4,925 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
251 (0.05/day)
Yes, vapor chamber technology is nice if you implement it correctly.
I'd use thermoelectric cooling if I were a GPU/CPU manufacturer.
291 (0.05/day)
South Green Jakarta
System Name Old Damned Rigs!
Processor AMD Phenom X4 9850 BE 2.5GHz
Motherboard MSI K9A2-CF
Memory 2 x 2GB DDR2 PC8500
Video Card(s) Nvidia Geforce 9800GT
Storage Hitachi 250GB Sata-II
Display(s) Chimnei 22" LCD Wide
Case Powerlogic Modena GTX2500
Power Supply Amacrox Warrior 400w
Software Windows XP Professional SP3
