Geometric Future - King Arthur (ITX to E-ATX)
674 (0.65/day)
Exreamly nice case by Geometric Future. Link https://www.geometricfuture.com/product-1/26.html
The case comes in a few different color ways - exxtreamly nice.
You may want to go back in and choose the "small image" option; that's just too much too large to easily manage heheh
All the images are straight from their website. The images take over my monitor.
They look to be well made cases that would do well in the US and abroad for the price, but it seems that they only have them for sale in China for now.
My self, I like the Caliburn Caliburn (geometricfuture.com), I also like that they put the buttons on the front panel so you don't have to worry about being catered while gamming.
Yes, the black case is exceptionally lovely, and that is my favorite color in the lineup.
Sad, they are only available in China. I wonder what it would take to get one.
It would be nice if this case had a vertical GPU layout.
I would never buy a case with the PSU mounted like that, so I guess it's good that we all have different taste and preferences.
Why not? PSU gets gresh air form the bottom other case and the heat is going out straight up and out?
I don't like connecting multiple high Voltage cables like that, as you always end up with the extension bit inside the case and if that gets damaged somehow, you get dead for starters.
And no, the PSU doesn't get all that much air like that either, but other cases are flawed in that sense as well, so not unique to this one. In this specific case, it's also going to cause some interesting turbulence, as the CPU cooler and the PSU will suck air from the same narrow space between the two, so the PSU ends up blocking a lot of the airflow to the CPU cooler.
One other thing I noticed, no air filter in the bottom of the case?
As I said, each to their own, this is not for me.
I got y
And no, the PSU doesn't get all that much air like that either, but other cases are flawed in that sense as well, so not unique to this one. In this specific case, you're also going to cause some interesting turbulence, as the CPU cooler and the PSU will but suck air from the same narrow space between the two, so the PSU ends up blocking a lot of the airflow to the CPU cooler.
I get you and that makes complete sense! nice pointing that tout, I never thought about it that way.
I got y
I guess it would be fine if you use a liquid cooler setup though, so it all comes down to the type of build you're doing.
There's no such thing as a perfect case.
