- Oct 9, 2007
- 47,659 (7.43/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
GIGABYTE is ready with its first AORUS-branded DDR5 memory kits. Pictured below is the first of its kind, which should give you an idea of the design for the series. The one pictured below is a DDR5-5200 two-module kit with 16 GB DIMMs, making up 32 GB, which is this generation's mainstream memory amount, as 16 GB (2x 8 GB) was for DDR4, and 8 GB for DDR3 (2x 4 GB). It features XMP 3.0, letting you effortlessly enable the advertised frequencies on a Z690 chipset motherboard. It's likely that the company designs other models with 8 GB DIMMs that have higher frequencies, or even 64 GB kits using "dual-rank" 32 GB DIMMs.
