- Dec 14, 2008
- 1,226 (0.20/day)
- The Netherlands
System Name | Silent allround |
Processor | i5 750 @ 3,0Ghz 1.04v / 3.4Ghz 1.11v/ 3,6Ghz 1.15v |
Motherboard | Gigabyte P55-USB3 |
Cooling | Thermalright IFX-14 + Scythe Slip Stream 140mm @ 600RPM |
Memory | 2 x 4GB Samsung M378B5273DH0-CH9 @ 2000 MHz 9-10-10-27 T1 |
Video Card(s) | Sapphire HD 5870 Vapor-X @ 940/1270 |
Storage | Intel Postville 80GB SSD & Western Digital Green 2TB |
Display(s) | Dell Ultrasharp U2412M |
Case | Bitfenix Merc Alpha |
Audio Device(s) | Asus Xonar D2 with Unified Drivers |
Power Supply | Nexus NX-5000 R3 530W |
Software | Windows 7 Home Premium x64 |
Benchmark Scores | Super pi 1M : 8,549s @ 4,7Ghz (Core i7 920) |
Introduction:
There was a thread about this beautiful Mini ITX motherboard on extremesystems, but TPU deserves one too.
CPU Coolers who'll fit on this mothboard:
Corsair H50,fits but standard backplate need's some modding. doesn't block pci-e/ memory slots.
CoolerMaster Hyper 212 Plus , doesn't block pci-e slot, can be hard to install when using memory with large heatspreaders
Thermalright Venomous X,apparently fits no info available on if it blocks the pci-e / memory slots.
Thermalright AXP-140, fits doesn't block pci-e/ memory slots.Perfect for using in a Lian LI PC-Q08
Scythe Shuriken, fits doesn't block pci-e but blocks memory slot
Prolimatech Samuel 17 , fits, doesn't block pci-e blocks but memory slots when using memory with high heatspreaders.
Scythe Ninja 3, fits but blocks pci-e slot.
Nexus Low-7000 aka Nexus Low-7000 R2, fits but blocks memory slot when using memory with high heatspreaders, blocks pci-e slot but can be solved by bending the heatsink a bit. Perfect for using in a Low profile case.
Mosfets cooling with heatsicks
My overclock result:
Reviews:
http://www.anandtech.com/show/3769/reviewed-gigabyte-h55nusb3-miniitx-done-the-gigabyte-way
http://www.bit-tech.net/hardware/mo.../gigabyte-ga-h55n-usb3-mini-itx-motherboard/1
http://www.overclock3d.net/reviews/cpu_mainboard/gigabyte_h55n_usb3/1
http://techgage.com/article/gigabyte_h55n-usb3_-_big_features_small_package/
http://www.hardwarezone.com/product-guide/view/47322/review/47323
http://www.madshrimps.be/?action=getarticle&articID=1051
http://www.tweaktown.com/reviews/34...l_h55_express_mini_itx_motherboard/index.html
http://lanoc.org/review/hardware/motherboards/4339-gigabyte-ga-h55n-usb3
http://www.pro-clockers.com/motherboards/1561-gigabyte-h55n-usb-30-itx-socket-1156-motherboard.html
http://www.techwarelabs.com/gigabyte-h55n-usb3/
http://www.motherboards.org/reviews/motherboards/2098_1.html
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=564&Itemid=69
http://www.xbitlabs.com/articles/mainboards/display/gigabyte-ga-h55n-usb3.html
http://www.silentpcreview.com/article1095-page1.html
http://www.ocia.net/reviews/h55nusb3/page1.shtml
useful links:
Gigabyte H55N-USB3 product page
Gigabyte H55N-USB3 Mini ITX overclocking and discussion thread at XtremeSystems Forums
"The GIGABYTE GA-H55N-USB3 was designed specifically for users wanting to build the ultimate home entertainment PC; small and sleek enough to seamlessly fit into the living room as part of the home, yet powerful enough to easily transfer, store and view today's many types of digital media content, whatever the format," commented Tim Handley, Deputy Director of Motherboard Marketing at GIGABYTE Technology Co. Ltd. "Not only does the GA-H55N-USB3 offer one of the industry's most exciting integrated graphics solutions with flawless HD video playback, it also allows users to spend less time waiting for their content to transfer, and more time to actually enjoy it due to its USB 3.0 GIGABYTE 3x USB Power Boost features."
XL ATX form factor
Mini-ITX form factor
Powered by the Intel® H55 chipset and supporting the latest Intel® Core™ i5 and Core™i3 LGA 1156 socket processors with integrated on-die graphics, the GIGABYTE GA-H55N-USB3 motherboard provides exceptional high definition content playback unmatched by previous integrated graphic solutions. The GIGABYTE GA-H55N-USB3 is also equipped with GIGABYTE 3x USB Power Boost and USB 3.0 support by utilizing the industry-leading NEC® controller, ensuring users are able to take advantage the next wave of high speed data transfer and storage technologies. Also supported is GIGABYTE's latest On/Off Charge technology, allowing users to fast charge their Apple devices including iPads, iPhones and iPod Touch devices even when the PS is powered off.
GIGABYTE has also designed the GA-H55N-USB3 motherboard to withstand the rigors of an always on device, both in terms of energy efficiency and temperature. Featuring the unique GIGABYTE Ultra Durable™ 3 design utilizing 2x the amount of copper of a traditional motherboard PCB, the GIGABYTE GA-H55N-USB3 provides better power efficiency and lower operating temperatures. The GA-H55N-USB3 is also equipped with the GIGABYTE Dynamic Energy Saver™ 2 for an even greater level of system-wide power savings and DualBIOS™ technology, which provides a back-up BIOS chip in case the main BIOS becomes corrupted or damaged.
More information about the GIGABYTE GA-H55N-USB3 motherboard is available from:
http://www.gigabyte.com/products/product-page.aspx?pid=3455#sp
Reviews:
useful links:
