chicofrito
- May 1, 2016
- 3 (0.00/day)
- Brazil
Hi guys can you help me I bought this VGA (Gigabyte HD7870 OC Edition) 4 years ago and everything was perfect till yesterday. I was playing Dota 2 then my PC froze with a green screen and artifacts, now after the boot sequence my PC just fall in a black screen but i can hear the windows sound logon. As you can see in the images even the BIOS is showing artifacts (blue dots), i cant boot in safe mode or any other mode unless i select "Enable low-resolution video (640x480)" I tried disconnecting and connecting everything, isopropyl alcohol, rubber to rub contacts but no luck. If i boot with the onboard GPU everything works perfect.
My specs are:
-Asus M4A785-M
-Phenom 2 x4 945
-4GB DDR2
-Corsair TX650W
I heard that the Power Supply degrades over time this is true? My Corsair TX650 must be 5 years old. Maybe the onboard GPU is not draining enough power to show errors? These are the voltages and artifacts: http://imgur.com/a/7fHjQ
Please help and sorry for the english im from brazil.
Thank you
My specs are:
-Asus M4A785-M
-Phenom 2 x4 945
-4GB DDR2
-Corsair TX650W
Thank you
