Deleted member 194470
Hello,
I have a 1660 super card and it shows the card connected to the monitor as a 'hdtv' and the higher resolutions are under a tv setting instead of a 'pc' setting. I contacted Nvidia about this several times and my monitor company and the monitor company blamed nvidia and nvidia blamed the monitor. Neither company was able to fix it. I suspected all along it was because of the type of cable I was using and that using hdmi confused the video card.
I changed to DVI and it stopped doing it. Although you can't change any of the settings like dynamic range when using dvi. Maybe it is already on the max settings? I read that hdmi/dvi is supposed to be the same quality but it looks slightly better with dvi. What could be causing the glitch.
Thanks
Thanks
