- May 8, 2023
- 65 (0.09/day)
so I've noticed that there's like a humming "mrrrr mrrrr mrrrr" sound from my PC, and it's definitely more pronounced when my ear is close to the PSU vent or near the bottom of the case, so I'm pretty confident it's the power supply (Phanteks Revolt 1000w)
it's not a buzz, it's more of a hum. it is primarily when under load, and definitely loudest when getting off a game, but it's not really high pitched and it doesn't strike me as coil whine; it's also not the fan exactly, I've been able to hear the fan separately from this noise
I'm going mad trying to figure out if this is just normal operating sound or if it's always been here (which it might've been, but it seems to be louder, especially today), or if something is up. the reason I'm posting about this is because usually when I have my ear close to the back of the PC vent, I can hear the GPU buzzing like normal very clearly, but sometimes this separate hum from the PSU is drowning it out, or at least existing very prominently alongside the GPU's typical coil whine
I took 2 videos while on a game, would recommend turning the volume to 100 to listen; it's a very constant and prominent hum like a "mrrr". important note is that it isn't ALWAYS present or noticeably loud; I sat on Elden Ring for a bit and never heard the noise, got on Roblox with some friends, heard it, got back on Elden Ring, heard it, got back on Roblox, couldn't hear anything
