Dizman7
- Jan 8, 2006
- 67 (0.01/day)
- Phoenix, AZ
Processor | AMD Opteron 165 Stock 1.8Ghz |
Motherboard | Asus A8N-32 Deluxe |
Cooling | Zalman CNPS9500 |
Memory | 4x 1GB OCZ Platinum DDR400 |
Video Card(s) | Asus nVidia 9800 GTX+ |
Storage | WD Raptor 74GB 10,000RPM SATA and Maxtor 250GB Storage SATA |
Display(s) | Gateway FPD2185W 21" Widescreen High-Definition LCD Flat-Panel Display |
Case | AeroCool AeroEngine2 |
Audio Device(s) | X-Fi Fatal1ty FPS |
Power Supply | Zalman 750W |
Software | Windows 7 64-bit |
I'm going to build an AthlonX2 system here soon and I've been trying to find a good airflow case, I'm not going to the extreme (or maybe norm for some of you) of water cooling just yet.
I plan on getting the Zalman CNPS9500 for the processor and I've already got a powersupply in mind. I'd "prefer" something blue, aluminium, with window and at least two 120mm fans (1 front, 1 back) and under $100. But I'm really looking for suggestions. Was looking at an AeroCool AeroEngine2 (http://www.newegg.com/Product/Product.asp?Item=N82E16811196019) but I dunno.
So I guess to limit this a bit I'm looking for great air flow, most I'll pay is $150 or under (under $100 would be better), don't need PSU (but if it comes with on that's ok), a window, and in blue, black, or silver. Oh and the less fans the better while still maintain good air flow. And easy installation is a plus. I sound picky but feel free to just throw things out there and I'll look at them.
Thanks!
So any suggetions?
Thanks!
So any suggetions?
