good cpu speed
217 (0.04/day)
ontario, canada
Processor Intel i5 3570K
Cooling lots of fans
Memory 16 GB ddr3
Video Card(s) AMD Radeon HD 7950
Case its red
Power Supply comes from hydro electricity generated from Niagara falls
Mouse Razer Death Adder Chroma
Software vista home 64 bit
what is the average speed that a cpu has to have to play games? i know all games are different but what would be a good speed to get?
Depends on the CPU. Anything Athlon X2/Core 2 and up, 3ghz+ is usually the sweet spot.
so if the cpu is
Core 2 Duo Mobile P8600 Dual-Core Processor (2x 2.4GHz/3MB Cache/1066FSB)
it would be fine?
would it be around 4.8 GHz
Only if the game supports multi threading, but in theory yes. However Laptops tend to struggle with gaming due to restricted GPU power / inadequate cooling and battery life.
k thanks people
so if the cpu is
it would be fine?
Nope won't be near 4.8 ghz. Will be 2.4ghz but there are two cpu's so things will get done simultaneously. Anway on a laptop cpu 2.4ghz is more than enough to play games.
so if the cpu is
it would be fine?
What DrPepper said, they don't combine.. That should be OK if combined with a powerful GPU and a high-ish resolution.
for gaming on a lappy, the gpu (graphics card) is more important really... as most lappies with a decent gpu will have a pretty decent processor
Is your laptop just for games? You'd get loads more for your money with a desktop!
so if the cpu is
it would be fine?
Damn people still go around saying this kind of stuff? Well i guess a i7 overclocked is 24Ghz then, hehe.
im just going to get a desktop instead. laptops aren't even that portable. if you want to use it it has to plugged into the charger anyways.
Your current graphic card is alright, I would keep that and upgrade motherboard + CPU + ram.
